Saltar al contenido principal
Asus G75VW-BHI7N07 Trackpad Buttons Replacement
Qué necesitas
  1. Asus G75VW-BHI7N07 Trackpad Buttons Replacement, Trackpad Buttons: paso 1, imagen 1 de 3 Asus G75VW-BHI7N07 Trackpad Buttons Replacement, Trackpad Buttons: paso 1, imagen 2 de 3 Asus G75VW-BHI7N07 Trackpad Buttons Replacement, Trackpad Buttons: paso 1, imagen 3 de 3
    • Remove the 5 (9 mm screws) around the outside edges of the back cover with the PH1 Phillips-head screwdriver.
    • Lift off the back cover using the opening tool.
  2. Asus G75VW-BHI7N07 Trackpad Buttons Replacement: paso 2, imagen 1 de 3 Asus G75VW-BHI7N07 Trackpad Buttons Replacement: paso 2, imagen 2 de 3 Asus G75VW-BHI7N07 Trackpad Buttons Replacement: paso 2, imagen 3 de 3
    • Remove the 10 (9 mm) screws marked 'A' using the PH1 Phillips-head screwdriver.
    • Remove the battery by pressing the slide release button.
    • Remove 2 more (9 mm) 'A' marked screws within the battery compartment using the PH1 Phillips-head screwdriver.
  3. Asus G75VW-BHI7N07 Trackpad Buttons Replacement: paso 3, imagen 1 de 2 Asus G75VW-BHI7N07 Trackpad Buttons Replacement: paso 3, imagen 2 de 2
    • Remove the cover for the disc drive with the opening tool.
    • Remove the 6 (4 mm) 'B' marked screws with the PH1 Phillips-head screwdriver. (3 screws are in the battery compartment and 3 are under the disc drive cover)
  4. Asus G75VW-BHI7N07 Trackpad Buttons Replacement: paso 4, imagen 1 de 2 Asus G75VW-BHI7N07 Trackpad Buttons Replacement: paso 4, imagen 2 de 2
    • Take off the henge cover using the opening tool.
    • Remove the 2 black outside edge (9 mm) screws with the J0 Phillips screwdriver.
  5. Asus G75VW-BHI7N07 Trackpad Buttons Replacement: paso 5, imagen 1 de 3 Asus G75VW-BHI7N07 Trackpad Buttons Replacement: paso 5, imagen 2 de 3 Asus G75VW-BHI7N07 Trackpad Buttons Replacement: paso 5, imagen 3 de 3
    • Pry open the keypad platform with the opening tool.
    • You will need to lift the keypad platform with your hands.
    • Remove all electrical connections using your hands.
  6. Asus G75VW-BHI7N07 Trackpad Buttons Replacement: paso 6, imagen 1 de 2 Asus G75VW-BHI7N07 Trackpad Buttons Replacement: paso 6, imagen 2 de 2
    • Take the 2 (3 mm) screws out of the trackpad using the PH1 Phillips screwdriver.
    • Remove the trackpad buttons using your hands.
Conclusión
Una persona más ha completado esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 21
Todo El Tiempo: 1,398
