Saltar al contenido principal
Asus G75VW-BHI7N07 Audio Jack Replacement
Qué necesitas
  1. Asus G75VW-BHI7N07 Audio Jack  Replacement, Audio Jack: paso 1, imagen 1 de 3 Asus G75VW-BHI7N07 Audio Jack  Replacement, Audio Jack: paso 1, imagen 2 de 3 Asus G75VW-BHI7N07 Audio Jack  Replacement, Audio Jack: paso 1, imagen 3 de 3
    • Remove the 5 (9 mm screws) around the outside edges of the back cover with the PH1 Phillips-head screwdriver.
    • Lift off the back cover using the opening tool.
  2. Asus G75VW-BHI7N07 Audio Jack  Replacement: paso 2, imagen 1 de 3 Asus G75VW-BHI7N07 Audio Jack  Replacement: paso 2, imagen 2 de 3 Asus G75VW-BHI7N07 Audio Jack  Replacement: paso 2, imagen 3 de 3
    • Remove the 10 (9 mm) screws marked 'A' using the PH1 Phillips-head screwdriver.
    • Remove the battery by pressing the slide release button.
    • Remove 2 more (9 mm) 'A' marked screws within the battery compartment using the PH1 Phillips-head screwdriver.
  3. Asus G75VW-BHI7N07 Audio Jack  Replacement: paso 3, imagen 1 de 2 Asus G75VW-BHI7N07 Audio Jack  Replacement: paso 3, imagen 2 de 2
    • Remove the cover for the disc drive with the opening tool.
    • Remove the 6 (4 mm) 'B' marked screws with the PH1 Phillips-head screwdriver. (3 screws are in the battery compartment and 3 are under the disc drive cover)
  4. Asus G75VW-BHI7N07 Audio Jack  Replacement: paso 4, imagen 1 de 2 Asus G75VW-BHI7N07 Audio Jack  Replacement: paso 4, imagen 2 de 2
    • Pry open the keypad platform with the opening tool.
    • You will need to lift the keypad platform with your hands to get to the laptop's internal systems.
  5. Asus G75VW-BHI7N07 Audio Jack  Replacement: paso 5, imagen 1 de 3 Asus G75VW-BHI7N07 Audio Jack  Replacement: paso 5, imagen 2 de 3 Asus G75VW-BHI7N07 Audio Jack  Replacement: paso 5, imagen 3 de 3
    • Take out 1 (5mm) screw, using the J0 Phillips head screwdriver.
    • Use the opening tool to remove the audio-electrical board.
    • Lift out with your hands.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 630
