Introducción
Use this guide will help you access the fans in order to clean or replace them.
Tools needed: size 0 Phillips head screwdriver, opening tool, metal spudger
Qué necesitas
Locate the 5 clips located at the top of the keyboard. Insert a metal spudger into the clip openings on the keyboard to remove the keyboard.
3 personas más completaron esta guía.
1 Guide Comment
Some steps missing, regarding screws to remove: 1 screw that holds optical drive; once that is removed, 2 screws in the drive compartment; 2 screws in the battery compartment; 3 screws from the bottom of the motherboard.
