Saltar al contenido principal
Asus G53JW-A1 Battery Replacement
  1. Asus G53JW-A1 Battery Replacement, Battery: paso 1, imagen 1 de 2 Asus G53JW-A1 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Start with the laptop upside-down.
    • Turn the laptop so that the battery is facing you.
  2. Asus G53JW-A1 Battery Replacement: paso 2, imagen 1 de 3 Asus G53JW-A1 Battery Replacement: paso 2, imagen 2 de 3 Asus G53JW-A1 Battery Replacement: paso 2, imagen 3 de 3
    • Look to the right of the battery for a small black switch.
    • Slide the right side switch to the right, away from the battery.
    • When the switch is in the correct position, a red sticker will be visible underneath the switch.
    • On the left side of the battery is another black switch. Slide this to the left, away from the battery, and hold it in place there.
    • The left side switch does not have a red sticker underneath.
    • Slide the battery towards yourself.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 15
Ultimos 30 días: 26
Todo El Tiempo: 287
