Introducción
A better RAM means a faster computer. A faulty RAM can cause applications to crash or malfunction. Be sure to have RAM compatible with your laptop when replacing it.
Qué necesitas
Flip laptop face down and rotate so the battery is facing toward you.
To remove the battery, place one finger on each of the two black slide tabs. Push each tab toward the center of the laptop to release the lock.
Slide the battery toward you and lift it out of the laptop.
With the laptop facing down, rotate it so the battery pack is facing away from you.
Remove the six 1.5 mm Phillips #1 screws on the back panel of the laptop.
You will hear a pop and visibly see the RAM move upwards.
Slide the RAM towards the back end of the laptop (the end with the battery), and lift up to remove it.
Una persona más ha completado esta guía.
