Saltar al contenido principal
Asus F6A-X2 Battery Replacement
  1. Asus F6A-X2 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Remove any power cords and turn the laptop off. Attempting to replace part of the laptop while power is running through it may cause electrocution or damage to the device.
    • Flip laptop face down and rotate so the battery is facing toward you.
    • The battery is not shown in this picture.
    • To remove the battery, place one finger on each of the two black slide tabs. Push each tab toward the center of the laptop to release the lock.
    • Slide the battery toward you and lift it out of the laptop.
Conclusión
Una persona más ha completado esta guía.
Jonathan
Miembro Desde 04/24/14
1,174 Reputación
11 Guías creadas
Equipo
Cal Poly, Team 10-56, Amido Spring 2014 Miembro de Cal Poly, Team 10-56, Amido Spring 2014
CPSU-AMIDO-S14S10G56
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 741
