Introducción
This guide will show how to install more RAM, or replace pre-existing RAM in your Asus F555LA-AB31 laptop. This laptop comes from the factory with 4gb of DDR3 SDRAM soldered to the motherboard. Behind the small panel located on the bottom of the Asus F555LA-AB31 there is one slot for installing additional memory.
Qué necesitas
Remove the Phillips #0 screw holding the RAM access panel in place.
Gently lift up on the edge of the panel to remove it.
To reassemble your device, reinstall the access panel by following these instructions in reverse order.
