Introducción
This guide has four uncomplicated and easy-to-follow steps to replace the CD drive of your Asus F555LA-AB31 laptop.
There are just two things that could be wrong with your CD drive. The first one is that you might have a faulty drive, which is highly unlikely. The second one, which is the most common problem, is faulty drivers; you may find that discs are not being read correctly.
Before completing this guide, unplug and turn off your laptop.
Qué necesitas
Use the Phillips #0 screwdriver head to remove the ten 18mm Phillips #0 screws on the laptop's bottom.
