Saltar al contenido principal
Asus F555LA-AB31 CD Drive Replacement
Qué necesitas
  1. Asus F555LA-AB31 CD Drive Replacement, CD Drive: paso 1, imagen 1 de 1
    • Turn off and unplug the device before starting repairing.
    • Use the Phillips #0 screwdriver head to remove the ten 18mm Phillips #0 screws on the laptop's bottom.
  2. Asus F555LA-AB31 CD Drive Replacement: paso 2, imagen 1 de 2 Asus F555LA-AB31 CD Drive Replacement: paso 2, imagen 2 de 2
    • Flip the laptop over and flip the screen up.
    • Pry upward on the edges of the faceplate in order to separate the keyboard and trackpad from the rest of the device.
    • Be cautious of the cables connecting the keyboard and trackpad to the motherboard.
  3. Asus F555LA-AB31 CD Drive Replacement: paso 3, imagen 1 de 1
    • Disconnect the keyboard flex cable from its motherboard ZIF socket.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap. Carefully slide the unlocked cable out of the socket.
  4. Asus F555LA-AB31 CD Drive Replacement: paso 4, imagen 1 de 2 Asus F555LA-AB31 CD Drive Replacement: paso 4, imagen 2 de 2
    • Use the Phillips #0 screwdriver to unscrew the one Phillips #0 screw that connects the CD drive to the motherboard.
    • Slowly slide out the CD drive, keeping it level, to remove it.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 384
