Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
If you are careful, the touch pad can be easily replaced. All you need is a #0 Phillips screwdriver and plastic opening tool to open the Asus notebook and remove your current touch pad. Before beginning this project, you should make sure that your notebook is not simply in need of a reboot. Also, before beginning your project, you need to shut down your note book and remove its charging cord.
Partes
No se especificaron partes.
  1. Make sure your notebook device is unplugged and turned off before opening it up. Flip the notebook over and remove the 10 screws from the back plate with a #0 Phillips head screwdriver. Six (6) will be 9.6mm and four (4) will be 12.7mm.
    • Make sure your notebook device is unplugged and turned off before opening it up.
    • Flip the notebook over and remove the 10 screws from the back plate with a #0 Phillips head screwdriver.
    • Six (6) will be 9.6mm and four (4) will be 12.7mm.
  2. Once the screws are removed, carefully lift both sides of the plastic keyboard/touch pad cover with a plastic opening tool. Once the screws are removed, carefully lift both sides of the plastic keyboard/touch pad cover with a plastic opening tool. Once the screws are removed, carefully lift both sides of the plastic keyboard/touch pad cover with a plastic opening tool.
    • Once the screws are removed, carefully lift both sides of the plastic keyboard/touch pad cover with a plastic opening tool.
  3. Kits de Reparación de Pantalla LCD de iPhone
    La opción de presupuesto, cubierta por nuestra garantía de por vida.
    Compra kits
    Reduce los costos de reparación, no la calidad.
    Compra kits
  4. Lift the plastic cover and unplug the three data cords (not all pictured) under the cover from the keyboard and motherboard.
    • Lift the plastic cover and unplug the three data cords (not all pictured) under the cover from the keyboard and motherboard.
  5. Once you've removed the plastic cover, flip it over. Next, carefully remove the tape from the bottom side of your touch pad. Next, carefully remove the tape from the bottom side of your touch pad.
    • Once you've removed the plastic cover, flip it over.
    • Next, carefully remove the tape from the bottom side of your touch pad.
  6. Locate and unscrew the three 3.2 mm at the top edge of the touch pad using the Phillips #0 screwdriver.
    • Locate and unscrew the three 3.2 mm at the top edge of the touch pad using the Phillips #0 screwdriver.
  7. Gently push the front of the touch pad with your finger to remove it from its position within the keyboard. Replace touch pad. Replace touch pad.
    • Gently push the front of the touch pad with your finger to remove it from its position within the keyboard.
    • Replace touch pad.
Conclusión
Clint Eagle
Miembro Desde 09/10/18
288 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S1-G2, Leahy Fall 2018 Miembro de USF Tampa, Team S1-G2, Leahy Fall 2018
USFT-LEAHY-F18S1G2
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 110
