Saltar al contenido principal
Asus EeeBook X205TA LED Screen Panel Chip Replacement
Qué necesitas
  1. Asus EeeBook X205TA LED Screen Panel Chip Replacement, Battery: paso 1, imagen 1 de 2 Asus EeeBook X205TA LED Screen Panel Chip Replacement, Battery: paso 1, imagen 2 de 2
    • Unscrew all ten 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
  2. Asus EeeBook X205TA LED Screen Panel Chip Replacement: paso 2, imagen 1 de 1
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA LED Screen Panel Chip Replacement: paso 3, imagen 1 de 2 Asus EeeBook X205TA LED Screen Panel Chip Replacement: paso 3, imagen 2 de 2
    • Unscrew all six 2mm screws using Philips #2 screws along the edges of the L-Shaped battery.
    • Any tape or cords that run along the battery should be carefully pushed to the side.
  4. Asus EeeBook X205TA LED Screen Panel Chip Replacement: paso 4, imagen 1 de 1
    • Disconnect the battery from the motherboard by pulling the No-Fuss Ribbon cables out of the connector.
  5. Asus EeeBook X205TA LED Screen Panel Chip Replacement: paso 5, imagen 1 de 1
    • Carefully lift the battery out of the laptop.
  6. Asus EeeBook X205TA LED Screen Panel Chip Replacement, LED Screen Panel Chip: paso 6, imagen 1 de 1
    • Locate and lift the tabs from the LED/motherboard ribbon cable.
    • Remove the cable.
  7. Asus EeeBook X205TA LED Screen Panel Chip Replacement: paso 7, imagen 1 de 1
    • Unscrew the 1 JIS 2mm screw with the J0 bit.
  8. Asus EeeBook X205TA LED Screen Panel Chip Replacement: paso 8, imagen 1 de 1
    • Remove the chip.
Conclusión
Rachael
Miembro Desde 03/20/17
125 Reputación
1 Guía escrita
Equipo
IUPUI, Team S3-G4, Baechle Spring 2017 Miembro de IUPUI, Team S3-G4, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G4
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 16
Todo El Tiempo: 1,160
