Saltar al contenido principal
Asus EeeBook X205TA Battery Replacement
Qué necesitas
  1. Asus EeeBook X205TA Battery Replacement, Battery: paso 1, imagen 1 de 2 Asus EeeBook X205TA Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Unscrew all ten 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
  2. Asus EeeBook X205TA Battery Replacement: paso 2, imagen 1 de 1
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA Battery Replacement: paso 3, imagen 1 de 2 Asus EeeBook X205TA Battery Replacement: paso 3, imagen 2 de 2
    • Unscrew all six 2mm screws using Philips #2 screws along the edges of the L-Shaped battery.
    • Any tape or cords that run along the battery should be carefully pushed to the side.
  4. Asus EeeBook X205TA Battery Replacement: paso 4, imagen 1 de 1
    • Disconnect the battery from the motherboard by pulling the No-Fuss Ribbon cables out of the connector.
  5. Asus EeeBook X205TA Battery Replacement: paso 5, imagen 1 de 1
    • Carefully lift the battery out of the laptop.
Conclusión
Follow the guide in reverse order to reassemble the device.
8 personas más completaron esta guía.
Equipo
USF Tampa, Team 2-2, Sullivan Fall 2016 Miembro de USF Tampa, Team 2-2, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G2
3 Miembros
10 Guías creadas
11 comentarios
By any chance , Can we run this laptop without battery ? I mean directly from AC ? Please suggest
Sourabh Verma - Contestar
No, you must have the battery on.
Tayler Grant -
is this under warenty
bla bla - Contestar
If you have one….
Tayler Grant -
My battery is stuck on orange led mode. My laptop cannot identify the battery….
Tayler Grant - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 14
Ultimos 30 días: 83
Todo El Tiempo: 13,840
