Saltar al contenido principal
Asus EeeBook X205TA USB Port Replacement
Qué necesitas
  1. Asus EeeBook X205TA  USB Port Replacement, USB Port: paso 1, imagen 1 de 2 Asus EeeBook X205TA  USB Port Replacement, USB Port: paso 1, imagen 2 de 2
    • Unscrew all 10 screws located on the bottom of the laptop using a Phillips #2 Screwdriver.
    • Keep in mind that some of the screws vary in length, so keep track of which screws were placed in each hole.
  2. Asus EeeBook X205TA  USB Port Replacement: paso 2, imagen 1 de 1
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA  USB Port Replacement: paso 3, imagen 1 de 2 Asus EeeBook X205TA  USB Port Replacement: paso 3, imagen 2 de 2
    • The USB ports are located on the strip that looks like the motherboard on the left side of the laptop next to the battery.
    • Unscrew the four screws using Philips #2 screwdriver located around the edge of the USB ports.
    • Unplug the battery ZIF connector from the USB ports.
  4. Asus EeeBook X205TA  USB Port Replacement: paso 4, imagen 1 de 1
    • Carefully remove the USB ports from the laptop.
Conclusión
3 personas más completaron esta guía.
Equipo
USF Tampa, Team 2-2, Sullivan Fall 2016 Miembro de USF Tampa, Team 2-2, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G2
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 2,512
