Introducción
If you have had problems with your Asus Eee PC T101MT overheating, this guide will help you replace it.
Qué necesitas
Turn the tablet over and open it up. Insert a nylon spudger into the slots above F1, F6, F10 to pry up the keyboard.
Peel the black strip off of the back of your Asus Eee PC T101MT to expose more screws. Remove screws from the outside of the device case (ten 7mm screws and two 8mm screws).
Casi Terminas!
Conclusión
