Introducción
The Asus Eee PC 900 uses a small solid state drive instead of a lrger hard drive. Use this guide to replace the SSD in the Asus Eee PC 900.
Qué necesitas
Slide the battery's locking tabs from the locked position to unlocked positions.
Remove the small sticker on the right side of the SSD/RAM compartment cover.
Remove the two 4.76 mm Phillips #0 screws securing the SSD/RAM compartment cover.
7 personas más completaron esta guía.
5 comentarios
Refering from this site: http://www.minipciessd.com/
It seems you'll need a miniPCIe SSD and not a m-sata (even if the form factor seems the same) and that's why your bios doesn't recognize it.
Same problem here. I ended up putting my “new!” 64GB SSD in an adaptor and used it for a few years until it wore out!
Evidently the chips aren’t much good as withstood less than 700GB of writes according to the onboard diagnostics.
Strangely enough the adaptor worked with the original 16GB SSD and the 64.
what kind of adapter you use? My ssd died….
