Introducción
Removing the top cover is a mandatory step before to access the keyboard screw and go deeper inside the Eee PC 1215N.
Turn the power off and turn the netbook upside down.
  • Turn the power off and turn the netbook upside down.
  • Slide both battery catches together to release the battery.
  • Slide the battery out.
While there is a fairly long list of tools listed here, I was able to complete the entire guide using only a 3/64" flathead mini screwdriver (the kind you get for $0.99). I replaced the stock 500GB 5400RPM drive with the updated 7200RPM slim drive of the same line with no issues. The BIOS picked it up immediately, and I need only reinstall an OS.
Tolidano - Contestar
Missing step: remove the two screws under the battery, otherwise the keyboard won’t come off
Andrea Borgia - Contestar
Locate the memory compartment.
  • Locate the memory compartment.
Agregar Comentario
Agregar Comentario
  • Using a Spudger, push both right and left metal clip to release one of the RAM module.
  • Slide out the RAM module.
  • Do the same with the second RAM module if necessary.
Agregar Comentario
  • Remove the screws as necessary.
    • For top cover removing, only remove the 2 bottom screws.
    • For Keyboard removing, remove all 4 screws.
    • The one short screw paterns to uper left screw hole directly on the PCB.
Agregar Comentario
  • Use a Plastic Opening Tools to release the top cover.
    • Start from the left side.
    • Go around on the bottom
    • Finish with the right side.
  • The top cover is still connected to the PCB with the touchpad ribbon. Handle it carefully.
excellent guide. but be careful - it's very easy to broke narrow plastic clip :(
Marcin Dudek - Contestar
  • Carefully slide the top cover to the bottom in order to see the touchpad connector on the PCB.
  • Use a Spudger to slide the conector attachment black part and release the ribbon from the PCB.
  • Now you can remove the top cover
Agregar Comentario
Conclusión
Gaetan
Miembro Desde 26/12/12
9,285 Reputación
30 Guías creadas
Unrelated. My Asus VX-6 recently had the blue USB 3.0 ports stop working. Now the Ethernet connection is intermittent, goes away, come back, over and over again. Are those 3 ports on the right hand side part of the main board or separate boards?
paul poco - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 9
Todo El Tiempo: 2,116
