Saltar al contenido principal
Asus Eee PC 1215N Hard Drive Replacement
Qué necesitas
  1. Asus Eee PC 1215N Hard Drive Replacement, Battery: paso 1, imagen 1 de 2 Asus Eee PC 1215N Hard Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Turn the power off and turn the netbook upside down.
    • Slide both battery catches together to release the battery.
    • Slide the battery out.
  2. Asus Eee PC 1215N Hard Drive Replacement, RAM: paso 2, imagen 1 de 3 Asus Eee PC 1215N Hard Drive Replacement, RAM: paso 2, imagen 2 de 3 Asus Eee PC 1215N Hard Drive Replacement, RAM: paso 2, imagen 3 de 3
    • Locate the memory compartment.
    • Using a Plastic Opening Tools, remove the screw rubber cover.
    • Remove the screw.
  3. Asus Eee PC 1215N Hard Drive Replacement: paso 3, imagen 1 de 1
    • Use a Plastic Opening Tools near the screw hole to release the cover.
    • Remove the cover
  4. Asus Eee PC 1215N Hard Drive Replacement: paso 4, imagen 1 de 2 Asus Eee PC 1215N Hard Drive Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Spudger
    $3.99
    Comprar
    • Using a Spudger, push both right and left metal clip to release one of the RAM module.
    • Slide out the RAM module.
    • Do the same with the second RAM module if necessary.
  5. Asus Eee PC 1215N Hard Drive Replacement, Top Cover (Touchpad): paso 5, imagen 1 de 1
    • Remove the screws as necessary.
    • For top cover removing, only remove the 2 bottom screws.
    • For Keyboard removing, remove all 4 screws.
    • The one short screw paterns to uper left screw hole directly on the PCB.
  6. Asus Eee PC 1215N Hard Drive Replacement: paso 6, imagen 1 de 3 Asus Eee PC 1215N Hard Drive Replacement: paso 6, imagen 2 de 3 Asus Eee PC 1215N Hard Drive Replacement: paso 6, imagen 3 de 3
    • Use a Plastic Opening Tools to release the top cover.
    • Start from the left side.
    • Go around on the bottom
    • Finish with the right side.
    • The top cover is still connected to the PCB with the touchpad ribbon. Handle it carefully.
  7. Asus Eee PC 1215N Hard Drive Replacement: paso 7, imagen 1 de 2 Asus Eee PC 1215N Hard Drive Replacement: paso 7, imagen 2 de 2
    Spudger
    $3.99
    Comprar
    • Carefully slide the top cover to the bottom in order to see the touchpad connector on the PCB.
    • Use a Spudger to slide the conector attachment black part and release the ribbon from the PCB.
    • Now you can remove the top cover
  8. Asus Eee PC 1215N Hard Drive Replacement, Keyboard: paso 8, imagen 1 de 3 Asus Eee PC 1215N Hard Drive Replacement, Keyboard: paso 8, imagen 2 de 3 Asus Eee PC 1215N Hard Drive Replacement, Keyboard: paso 8, imagen 3 de 3
    • Make sure that the two upper screws inside the RAM compartment are removed before to continue. (Refer to Step 5).
    • Remove the keyboard 4 screws on the bottom.
    • Use a Plastic Opening Tools to release the keyboard clips on the left and right side.
  9. Asus Eee PC 1215N Hard Drive Replacement: paso 9, imagen 1 de 1
    Spudger
    $3.99
    Comprar
    • At this step, the keyboard is still maintained with double-sided tape between the keyboard underside and the metallic PCB protector.
    • Carefully slide a Spudger between the keyboard underside and the metallic PCB protector near the center/right at the bottom. Use the spudger as a lever to release the keyboard from the metallic PCB protector.
    • The keyboard is still connected to the PCB with a ribbon. Handle it carefully.
  10. Asus Eee PC 1215N Hard Drive Replacement: paso 10, imagen 1 de 2 Asus Eee PC 1215N Hard Drive Replacement: paso 10, imagen 2 de 2
    Spudger
    $3.99
    Comprar
    • Carefully slide the keyboard to the top in order to see the ribbon connector on the PCB.
    • Use a Spudger to slide the connector attachment black part and release the ribbon from the PCB.
    • Now you can remove the keyboard.
  11. Asus Eee PC 1215N Hard Drive Replacement, Metallic PCB protector plate: paso 11, imagen 1 de 3 Asus Eee PC 1215N Hard Drive Replacement, Metallic PCB protector plate: paso 11, imagen 2 de 3 Asus Eee PC 1215N Hard Drive Replacement, Metallic PCB protector plate: paso 11, imagen 3 de 3
    • Peel off the protective tape at the bottom left corner.
    • Peel off the warranty void at the bottom right corner and remove the screw below.
    • Remove the 6 other screws.
  12. Asus Eee PC 1215N Hard Drive Replacement: paso 12, imagen 1 de 2 Asus Eee PC 1215N Hard Drive Replacement: paso 12, imagen 2 de 2
    • Remove the protector plate.
  13. Asus Eee PC 1215N Hard Drive Replacement, Hard Drive: paso 13, imagen 1 de 3 Asus Eee PC 1215N Hard Drive Replacement, Hard Drive: paso 13, imagen 2 de 3 Asus Eee PC 1215N Hard Drive Replacement, Hard Drive: paso 13, imagen 3 de 3
    • Remove the four Phillips #00 screws from the hard drive caddy.
    • Peel off any tape covering the hard drive, there is no need to remove it entirely.
  14. Asus Eee PC 1215N Hard Drive Replacement: paso 14, imagen 1 de 3 Asus Eee PC 1215N Hard Drive Replacement: paso 14, imagen 2 de 3 Asus Eee PC 1215N Hard Drive Replacement: paso 14, imagen 3 de 3
    • Unplug the hard drive by sliding it to the right, toward the USB ports.
    • Remove the hard drive.
Conclusión
25 personas más completaron esta guía.
Gaetan
Miembro Desde 12/26/12
9,574 Reputación
18 Guías creadas
7 comentarios
I've just upgraded my 1215N HDD using this guide. This is very good step by step guide. A WIndows 10 Pro install managed to wreck the pre-installed HDD.
Like Tolidano , I just used a normal flat head screwdriver and a Philips screwdriver to carry out the HDD swap. I'm now in the process of installing Windows 10 Pro on to the new HDD.
Richard Bijster - Contestar
Very good guide! I my case i need to remove 2 screws from the battery compartment to remove the keyboard
gus - Contestar
I also had to remove the two (tiny, but phillips #00) screws from the battery compartment.
I actually went further and removed the motherboard to clean the fan. It wasn't too hard thanks to your guide!
Franciozzy - Contestar
I, too had to remove the battery compartment screws. Other than that, and that I couldn’t get the keyboard cable out, the replacement went flawlessly.
Guy, Just Some -
Great stuff, swapped original HD for an SSD. Thank you for this!
Steven - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 27
Todo El Tiempo: 15,813
