Saltar al contenido principal
Asus Eee PC 1201N RAM Replacement
Qué necesitas
  1. Asus Eee PC 1201N RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the netbook over.
    • Be sure to unplug the netbook and power off the device while working.
  2. Asus Eee PC 1201N RAM Replacement: paso 2, imagen 1 de 1
    • Push open both tabs on either side of the battery.
    • The tab on the left will click open and stay in place until you close it.
  3. Asus Eee PC 1201N RAM Replacement: paso 3, imagen 1 de 1
    • Pull the tab on the right open, while you remove battery with your other hand.
    • Pull the battery straight out ensuring that you don't damage any connectors.
  4. Asus Eee PC 1201N RAM Replacement, RAM: paso 4, imagen 1 de 2 Asus Eee PC 1201N RAM Replacement, RAM: paso 4, imagen 2 de 2
    • Remove the two 4.6mm screws using the J0 Phillips head screwdriver.
    • Then use the plastic opening tool to open the RAM door.
  5. Asus Eee PC 1201N RAM Replacement: paso 5, imagen 1 de 1
    • Push the tabs on the side of the RAM to release.
    • Only push the tabs over slightly to ensure you do not break them.
  6. Asus Eee PC 1201N RAM Replacement: paso 6, imagen 1 de 1
    • Remove the RAM by pulling it towards you.
Conclusión
Trae Mikesell
Miembro Desde 10/04/16
394 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 2-3, Nance Fall 2016 Miembro de USF Tampa, Team 2-3, Nance Fall 2016
USFT-NANCE-F16S2G3
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 1,022
