Saltar al contenido principal
Asus Eee PC 1201N Keyboard Replacement
Qué necesitas
  1. Asus Eee PC 1201N Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the netbook over.
    • Be sure to unplug the netbook and power off the device while working.
  2. Asus Eee PC 1201N Keyboard Replacement: paso 2, imagen 1 de 1
    • Push open both tabs on either side of the battery.
    • The tab on the left will click open and stay in place until you close it.
  3. Asus Eee PC 1201N Keyboard Replacement: paso 3, imagen 1 de 1
    • Pull the tab on the right open, while you remove battery with your other hand.
    • Pull the battery straight out ensuring that you don't damage any connectors.
  4. Asus Eee PC 1201N Keyboard Replacement, Keyboard: paso 4, imagen 1 de 2 Asus Eee PC 1201N Keyboard Replacement, Keyboard: paso 4, imagen 2 de 2
    • Open the netbook to find the four small grooves along the top of the keyboard.
    • Pry the keyboard up using the plastic opening tool.
  5. Asus Eee PC 1201N Keyboard Replacement: paso 5, imagen 1 de 2 Asus Eee PC 1201N Keyboard Replacement: paso 5, imagen 2 de 2
    • Tilt the keyboard away from you to access the connector. Gently push the lock toward the screen to unlock it and slide the ribbon out.
    • Remove the keyboard.
Conclusión
Una persona más ha completado esta guía.
Trae Mikesell
Miembro Desde 10/04/16
394 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 2-3, Nance Fall 2016 Miembro de USF Tampa, Team 2-3, Nance Fall 2016
USFT-NANCE-F16S2G3
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 465
