Saltar al contenido principal
Asus Eee PC 1201N Cooling fan replacement
Qué necesitas
  1. Asus Eee PC 1201N Cooling fan replacement, Battery: paso 1, imagen 1 de 1
    • Flip the netbook over.
    • Be sure to unplug the netbook and power off the device while working.
  2. Asus Eee PC 1201N Cooling fan replacement: paso 2, imagen 1 de 1
    • Push open both tabs on either side of the battery.
    • The tab on the left will click open and stay in place until you close it.
  3. Asus Eee PC 1201N Cooling fan replacement: paso 3, imagen 1 de 1
    • Pull the tab on the right open, while you remove battery with your other hand.
    • Pull the battery straight out ensuring that you don't damage any connectors.
  4. Asus Eee PC 1201N Cooling fan replacement, Keyboard: paso 4, imagen 1 de 2 Asus Eee PC 1201N Cooling fan replacement, Keyboard: paso 4, imagen 2 de 2
    • Open the netbook to find the four small grooves along the top of the keyboard.
    • Pry the keyboard up using the plastic opening tool.
  5. Asus Eee PC 1201N Cooling fan replacement: paso 5, imagen 1 de 2 Asus Eee PC 1201N Cooling fan replacement: paso 5, imagen 2 de 2
    • Tilt the keyboard away from you to access the connector. Gently push the lock toward the screen to unlock it and slide the ribbon out.
    • Remove the keyboard.
  6. Asus Eee PC 1201N Cooling fan replacement, Cooling fan: paso 6, imagen 1 de 1
    • Remove the eight 6.5mm screws using the J0 Phillips head screwdriver from back of the netbook.
  7. Asus Eee PC 1201N Cooling fan replacement: paso 7, imagen 1 de 2 Asus Eee PC 1201N Cooling fan replacement: paso 7, imagen 2 de 2
    • Remove the ten 4.5 mm screws from cover plate using the J0 Phillips head screwdriver.
    • Remove the cover plate by sliding the plastic opening tool around the entire edge of the plate.
  8. Asus Eee PC 1201N Cooling fan replacement: paso 8, imagen 1 de 1
    • Pull the blue tab for the touchpad connector before removing the cover plate completely.
  9. Asus Eee PC 1201N Cooling fan replacement: paso 9, imagen 1 de 1
    • Remove the two 4.6 mm screws from the cover plate using the J0 Phillips head screwdriver.
  10. Asus Eee PC 1201N Cooling fan replacement: paso 10, imagen 1 de 1
    • Unplug the connector.
  11. Asus Eee PC 1201N Cooling fan replacement: paso 11, imagen 1 de 1
    • Lift up and remove the fan.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 2-3, Nance Fall 2016 Miembro de USF Tampa, Team 2-3, Nance Fall 2016
USFT-NANCE-F16S2G3
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 14
Todo El Tiempo: 948
