Saltar al contenido principal
Asus Eee PC 1201HAB Hard Drive Replacement
Qué necesitas
  1. Asus Eee PC 1201HAB Hard Drive Replacement, Keyboard: paso 1, imagen 1 de 2 Asus Eee PC 1201HAB Hard Drive Replacement, Keyboard: paso 1, imagen 2 de 2
    • Use a plastic opening tool and carefully pry the top panel from the base.
  2. Asus Eee PC 1201HAB Hard Drive Replacement: paso 2, imagen 1 de 3 Asus Eee PC 1201HAB Hard Drive Replacement: paso 2, imagen 2 de 3 Asus Eee PC 1201HAB Hard Drive Replacement: paso 2, imagen 3 de 3
    • Slowly lift the keyboard from the base.
    • Disconnect the attached ribbon from under the keyboard.
  3. Asus Eee PC 1201HAB Hard Drive Replacement: paso 3, imagen 1 de 1
    • Remove the keyboard.
  4. Asus Eee PC 1201HAB Hard Drive Replacement, Hard Drive: paso 4, imagen 1 de 2 Asus Eee PC 1201HAB Hard Drive Replacement, Hard Drive: paso 4, imagen 2 de 2
    • Lay the laptop with the back facing up.
    • With a Phillips #0 screwdriver, remove the eight 6mm screws on the back of the laptop.
  5. Asus Eee PC 1201HAB Hard Drive Replacement: paso 5, imagen 1 de 3 Asus Eee PC 1201HAB Hard Drive Replacement: paso 5, imagen 2 de 3 Asus Eee PC 1201HAB Hard Drive Replacement: paso 5, imagen 3 de 3
    • Slide the tabs outward to remove the battery.
  6. Asus Eee PC 1201HAB Hard Drive Replacement: paso 6, imagen 1 de 2 Asus Eee PC 1201HAB Hard Drive Replacement: paso 6, imagen 2 de 2
    • Flip the device so that you are facing the screen.
    • Remove the ten 4mm screws on the silver panel under the keyboard using a Phillips #0 screwdriver.
  7. Asus Eee PC 1201HAB Hard Drive Replacement: paso 7, imagen 1 de 3 Asus Eee PC 1201HAB Hard Drive Replacement: paso 7, imagen 2 de 3 Asus Eee PC 1201HAB Hard Drive Replacement: paso 7, imagen 3 de 3
    • Using a plastic opening tool, remove the top panel of the laptop.
  8. Asus Eee PC 1201HAB Hard Drive Replacement: paso 8, imagen 1 de 2 Asus Eee PC 1201HAB Hard Drive Replacement: paso 8, imagen 2 de 2
    • Using a Phillips #0 screwdriver, remove the four 4mm screws connecting the hard drive.
  9. Asus Eee PC 1201HAB Hard Drive Replacement: paso 9, imagen 1 de 1
    • Remove and replace the hard drive.
Conclusión
Una persona más ha completado esta guía.
Katherine Chan
Miembro Desde 10/22/18
353 Reputación
2 Guías creadas
Equipo
UC Davis, Team S7-G3, Lore Fall 2018 Miembro de UC Davis, Team S7-G3, Lore Fall 2018
UCD-LORE-F18S7G3
3 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 37
Todo El Tiempo: 798
