Saltar al contenido principal
Asus Eee PC 1008ha Trackpad Mouse Clicker Replacement
Qué necesitas
  1. Asus Eee PC 1008ha Trackpad Mouse Clicker Replacement, Trackpad Mouse Clicker (the button's on the bottom of the trackpad): paso 1, imagen 1 de 1
    • Use an opening too to carefully separate the palm rest assembly from the base of the laptop.
    • Move the opening tool around the perimeter of the palm rest and the base and use it as a wedge.
    • You will need to undo the clips holding the two parts together with the opening tool. Be careful not to break the clips.
  2. Asus Eee PC 1008ha Trackpad Mouse Clicker Replacement: paso 2, imagen 1 de 2 Asus Eee PC 1008ha Trackpad Mouse Clicker Replacement: paso 2, imagen 2 de 2
    • Use a spudger to open the cable locks and remove the ribbon cables using your hands or tweezers.
    • Using a Phillips #00 screwdriver, remove the two 4 mm screws on either side of the circuit board.
Conclusión
Una persona más ha completado esta guía.
Michael Dooley
Miembro Desde 04/18/13
138 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 21-52, Johann Spring 2013 Miembro de Cal Poly, Team 21-52, Johann Spring 2013
CPSU-JOHANN-S13S21G52
4 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 891
