Saltar al contenido principal
Asus Eee PC 1008ha Graphics Card Replacement
Qué necesitas
  1. Asus Eee PC 1008ha Graphics Card Replacement, Battery: paso 1, imagen 1 de 1
    • Using the plastic opening tool, carefully pry the top panel from the base.
  2. Asus Eee PC 1008ha Graphics Card Replacement: paso 2, imagen 1 de 3 Asus Eee PC 1008ha Graphics Card Replacement: paso 2, imagen 2 de 3 Asus Eee PC 1008ha Graphics Card Replacement: paso 2, imagen 3 de 3
    • Lift the side of the keyboard.
    • Disconnect the attached ribbon located underneath the keyboard.
    • Place your index finger in the hole on the right side of the keyboard tray and lift the tray.
  3. Asus Eee PC 1008ha Graphics Card Replacement: paso 3, imagen 1 de 2 Asus Eee PC 1008ha Graphics Card Replacement: paso 3, imagen 2 de 2
    • Use your fingers to lift the battery and gently disconnect the wires from the base.
  4. Asus Eee PC 1008ha Graphics Card Replacement, Graphics Card: paso 4, imagen 1 de 1
    • Remove the two 2mm screws from the graphics card.
  5. Asus Eee PC 1008ha Graphics Card Replacement: paso 5, imagen 1 de 3 Asus Eee PC 1008ha Graphics Card Replacement: paso 5, imagen 2 de 3 Asus Eee PC 1008ha Graphics Card Replacement: paso 5, imagen 3 de 3
    • Flip over the graphics card.
    • Pull the black plastic locking mechanism towards the golden ribbon to unlock.
    • Pull out the ribbon.
Conclusión
Una persona más ha completado esta guía.
Alex Powers
Miembro Desde 04/17/13
101 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 21-52, Johann Spring 2013 Miembro de Cal Poly, Team 21-52, Johann Spring 2013
CPSU-JOHANN-S13S21G52
4 Miembros
11 Guías creadas
Un comentario
Is this the graphics card?
Is this pc has no integrated graphics card?
JUAN LUIS GARCIA BRAVO - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 3,608
