Saltar al contenido principal
Asus Eee PC 1005PEB Battery Replacement
  1. Asus Eee PC 1005PEB Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Start by placing the laptop upside-down on a flat surface.
    • Find the two clips on the back portion of the laptop.
  2. Asus Eee PC 1005PEB Battery Replacement: paso 2, imagen 1 de 1
    • Using your finger, push the clip labeled with a "1" on the laptop from the lock position to unlock position.
    • This clip will hold itself, so after you move it to the unlock position you can remove your finger.
  3. Asus Eee PC 1005PEB Battery Replacement: paso 3, imagen 1 de 2 Asus Eee PC 1005PEB Battery Replacement: paso 3, imagen 2 de 2
    • Using your finger, push and hold the pin indicated by a "2" on the laptop from the lock to unlock position.
    • While holding this pin in the unlock position, use your other hand to pull the battery horizontally away from the laptop.
    • When the pins on the battery that reach towards the laptop are away from the laptop, you can release the "2" clip.
  4. Asus Eee PC 1005PEB Battery Replacement: paso 4, imagen 1 de 1
    • Using both hands, pull the battery horizontally away from the laptop.
Conclusión
2 personas más completaron esta guía.
Aaron Arenas
Miembro Desde 04/20/14
751 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 13-32, Maness Spring 2014 Miembro de Cal Poly, Team 13-32, Maness Spring 2014
CPSU-MANESS-S14S13G32
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 1,548
