Saltar al contenido principal
Asus Eee PC 1005HA Bluetooth Module Replacement
Qué necesitas
  1. Asus Eee PC 1005HA Bluetooth Module Replacement, Keyboard: paso 1, imagen 1 de 2 Asus Eee PC 1005HA Bluetooth Module Replacement, Keyboard: paso 1, imagen 2 de 2
    • Use a plastic opening tool to pull up the four metal latches in the battery cavity that is located on the bottom of the laptop.
    • Do not apply too much pressure. The latches can not be removed and will bend if forced.
  2. Asus Eee PC 1005HA Bluetooth Module Replacement: paso 2, imagen 1 de 3 Asus Eee PC 1005HA Bluetooth Module Replacement: paso 2, imagen 2 de 3 Asus Eee PC 1005HA Bluetooth Module Replacement: paso 2, imagen 3 de 3
    • Flip the laptop over, and open the display.
    • Use a plastic opening tool to lift the edge of the keyboard that is nearest to the screen.
    • Gently lift the keyboard and slide it toward the screen.
    • Do not remove the keyboard completely. This can damage the ribbon cable connecting the underside of the keyboard to the laptop.
  3. Asus Eee PC 1005HA Bluetooth Module Replacement: paso 3, imagen 1 de 1
    • Use a spudger tool to release the tabs on the ribbon cable ZIF connector that is attached to the underside of the keyboard.
    • Depending on the model, the tabs on this ZIF connector will either flip up toward the display or push out toward the display.
    • Once the ZIF connector tabs have been released, remove the keyboard.
  4. Asus Eee PC 1005HA Bluetooth Module Replacement, Bluetooth Module: paso 4, imagen 1 de 2 Asus Eee PC 1005HA Bluetooth Module Replacement, Bluetooth Module: paso 4, imagen 2 de 2
    • Flip the laptop over.
    • Using a Phillips #1 screwdriver, remove the five 5.65 mm screws.
    • The screw that holds the RAM compartment cover may be permanently connected. This screw is the center most screw of the five.
    • Be sure to have a designated place to hold the different sized screws removed in this guide.
  5. Asus Eee PC 1005HA Bluetooth Module Replacement: paso 5, imagen 1 de 3 Asus Eee PC 1005HA Bluetooth Module Replacement: paso 5, imagen 2 de 3 Asus Eee PC 1005HA Bluetooth Module Replacement: paso 5, imagen 3 de 3
    • Remove the lid to the RAM compartment, if possible.
    • To remove the RAM, depress the tabs that are holding it in. These tabs are bound in red in the picture.
    • Use a spudger to unclip the edges of the cover if necessary.
    • The battery is shown still attached in the picture, but it should be removed prior to beginning this guide.
  6. Asus Eee PC 1005HA Bluetooth Module Replacement: paso 6, imagen 1 de 1
    • Use a Phillips #1 screwdriver to remove one 6.5 mm screw located next to the RAM.
  7. Asus Eee PC 1005HA Bluetooth Module Replacement: paso 7, imagen 1 de 2 Asus Eee PC 1005HA Bluetooth Module Replacement: paso 7, imagen 2 de 2
    • Flip the laptop back over, and open the display.
    • Use a Phillips #1 screwdriver to remove the six 5.5 mm screws on the inside covering.
  8. Asus Eee PC 1005HA Bluetooth Module Replacement: paso 8, imagen 1 de 2 Asus Eee PC 1005HA Bluetooth Module Replacement: paso 8, imagen 2 de 2
    • Detach the five plastic clips holding the upper and lower halves of the laptop together. These can be undone by carefully running a plastic opening tool between the top and bottom casing. There will be an audible audible "click" as the clips come undone.
    • The top plastic is fragile. There are also two miniature LEDs exposed along the top edge of the bottom casing at the bottom right that are easily damaged.
    • Once the five clips have been undone, carefully remove the upper half of the laptop.
  9. Asus Eee PC 1005HA Bluetooth Module Replacement: paso 9, imagen 1 de 1
    • Detach the track pad ribbon by using a plastic opening tool to raise up the black pad.
  10. Asus Eee PC 1005HA Bluetooth Module Replacement: paso 10, imagen 1 de 2 Asus Eee PC 1005HA Bluetooth Module Replacement: paso 10, imagen 2 de 2
    • Detach the Bluetooth wire located below the fan by gently pulling it upward.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 5,261
