Introducción
In this guide, we'll show you how to replace the keyboard on the Asus PC EEE 1000HD completely. For this process, you will need a metal spudger tool for powerful prying. You will also need a (preferably) new replacement keyboard.
Qué necesitas
Note: Prior to changing the keyboard on your laptop, be sure to have a replacement keyboard on hand.
Use a metal spudger and carefully insert the end of the flat tip into the edge of the keyboard.
Hold one end of the keyboard down to make prying easier.
Gently lift the metal spudger until you begin hearing clicking noises; these are the sounds of the keyboard unclasping from the board below.
