Saltar al contenido principal
Asus Chromebook Flip C302CA Display Replacement
Qué necesitas
  1. Asus Chromebook Flip C302CA Display Replacement, Back Panel: paso 1, imagen 1 de 1
    • Turn the laptop over so the bottom is facing you.
  2. Asus Chromebook Flip C302CA Display Replacement: paso 2, imagen 1 de 3 Asus Chromebook Flip C302CA Display Replacement: paso 2, imagen 2 de 3 Asus Chromebook Flip C302CA Display Replacement: paso 2, imagen 3 de 3
    • Remove two rubber caps on the top.
    • Remove the two 1 mm screws using the Phillips #00 screwdriver.
  3. Asus Chromebook Flip C302CA Display Replacement: paso 3, imagen 1 de 3 Asus Chromebook Flip C302CA Display Replacement: paso 3, imagen 2 de 3 Asus Chromebook Flip C302CA Display Replacement: paso 3, imagen 3 de 3
    • Remove the ten 2 mm screws from the back panel using a T5 Torx screwdriver.
    • Carefully remove the back panel using an opening pick.
  4. Asus Chromebook Flip C302CA Display Replacement: paso 4, imagen 1 de 2 Asus Chromebook Flip C302CA Display Replacement: paso 4, imagen 2 de 2
    • Remove the back panel from the laptop.
  5. Asus Chromebook Flip C302CA Display Replacement, Display: paso 5, imagen 1 de 1
    • Remove the black display ports from the motherboard.
  6. Asus Chromebook Flip C302CA Display Replacement: paso 6, imagen 1 de 1
    • Remove the six 2.54 mm Phillips screws from the left and right screen hinge brackets.
  7. Asus Chromebook Flip C302CA Display Replacement: paso 7, imagen 1 de 1
    • Remove the display unit.
  8. Asus Chromebook Flip C302CA Display Replacement: paso 8, imagen 1 de 1
    • Use heat gun to loosen up adhesive on rubber covers for screw.
  9. Asus Chromebook Flip C302CA Display Replacement: paso 9, imagen 1 de 1
    • Remove rubber covers.
  10. Asus Chromebook Flip C302CA Display Replacement: paso 10, imagen 1 de 1
    • Remove the two 2.5 mm screws.
  11. Asus Chromebook Flip C302CA Display Replacement: paso 11, imagen 1 de 1
    • Use prying tool to separate panel from monitor.
  12. Asus Chromebook Flip C302CA Display Replacement: paso 12, imagen 1 de 1
    • Remove this connection by pulling to separate it from the monitor.
  13. Asus Chromebook Flip C302CA Display Replacement: paso 13, imagen 1 de 1
    • Remove connection point and the entire camera assembly including wires.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 13
Todo El Tiempo: 237
