Saltar al contenido principal
Asus Chromebook Flip C100P Power and Volume Buttons Replacement
Qué necesitas
  1. Asus Chromebook Flip C100P Power and Volume Buttons Replacement, Power and Volume Buttons: paso 1, imagen 1 de 1
    • Remove three of the rubber feet on the bottom cover with a plastic or metal spudger.
  2. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: paso 2, imagen 1 de 1
    • Remove the five screws from beneath the rubber feet using a philips head screwdriver. The first 1.9mm screw is located under the front right foot, the second 1.9mm screw and third 2.3mm screw are located under the rear right foot, and the fourth and fifth 2.3mm screws are located under the rear left foot.
  3. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: paso 3, imagen 1 de 1
    • Remove the eight 3mm bottom cover screws and one 6mm screw using a T5 screwdriver. Set apart the screw in the rear middle of the bottom cover from the the other eight screws, as it is longer than them.
  4. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: paso 4, imagen 1 de 3 Asus Chromebook Flip C100P Power and Volume Buttons Replacement: paso 4, imagen 2 de 3 Asus Chromebook Flip C100P Power and Volume Buttons Replacement: paso 4, imagen 3 de 3
    • Pry the palm rest assembly apart from the bottom cover using a spudger. This step may require a bit of elbow grease. Once the palm rest has been separated from the bottom cover, pull it away from the screen, rather than away from yourself.
  5. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: paso 5, imagen 1 de 3 Asus Chromebook Flip C100P Power and Volume Buttons Replacement: paso 5, imagen 2 de 3 Asus Chromebook Flip C100P Power and Volume Buttons Replacement: paso 5, imagen 3 de 3
    • Disconnect the touchpad cable and the keyboard cable on the palm rest assembly from the motherboard using the pointed end of a plastic spudger.
  6. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: paso 6, imagen 1 de 2 Asus Chromebook Flip C100P Power and Volume Buttons Replacement: paso 6, imagen 2 de 2
    • Flip up the white part of the connector using the pointed end of a plastic spudge.
  7. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: paso 7, imagen 1 de 1
    • Pull the cable out by the blue tab.
  8. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: paso 8, imagen 1 de 1
    • Unscrew two 2.7 mm screws using the Phillips #0 screwdriver.
  9. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: paso 9, imagen 1 de 1
    • Remove the button chip.
  10. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: paso 10, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Using tweezers, carefully pull out the external buttons.
Conclusión
Una persona más ha completado esta guía.
Andrew Thomson
Miembro Desde 03/19/18
181 Reputación
1 Guía escrita
Equipo
Baylor, Team S5-G2, Williams Spring 2018 Miembro de Baylor, Team S5-G2, Williams Spring 2018
BU-WILLIAMS-S18S5G2
Miembros de 3
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 868
