Saltar al contenido principal
Asus Chromebook Flip C100P Battery Replacement
Qué necesitas
  1. Asus Chromebook Flip C100P Battery Replacement, Lower Case: paso 1, imagen 1 de 1
    • Unscrew the eight bottom cover screws (one of them is under the hand) using a screwdriver with a J1000 tip.
    • Unscrew the middle screw towards the top of the device using a screwdriver with a T5 tip.
  2. Asus Chromebook Flip C100P Battery Replacement: paso 2, imagen 1 de 1
    • Use the plastic opening tool to remove the four bottom rubber feet.
  3. Asus Chromebook Flip C100P Battery Replacement: paso 3, imagen 1 de 1
    • Unscrew the four screws under the feet using a screwdriver with a J100 tip.
  4. Asus Chromebook Flip C100P Battery Replacement: paso 4, imagen 1 de 1
    • Use the plastic opening tool to pry up the palm rest assembly.
  5. Asus Chromebook Flip C100P Battery Replacement: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Disconnect the two cables from the motherboard with tweezers
  6. Asus Chromebook Flip C100P Battery Replacement, Battery: paso 6, imagen 1 de 1
    • Unscrew the four J1 Screws of the Audio Cards
  7. Asus Chromebook Flip C100P Battery Replacement: paso 7, imagen 1 de 1
    • Unscrew the three Battery Screws by using a screwdriver with a J00 tip.
  8. Asus Chromebook Flip C100P Battery Replacement: paso 8, imagen 1 de 1
    • Lift the battery cable out of Mother Board
Conclusión
To reassemble your device and complete the battery replacement, please follow these instructions in reverse order.
12 personas más completaron esta guía.
2 comentarios
The difficulty rating should be higher. The sound card does not need to be removed, but this is not mentioned. I only noticed it from the next picture. Reattaching the keyboard cable is very difficult; a hint with tips would help.
Chas Hofmeister - Contestar
I had to searched high and low for this but I'm glad I found this site. Thanks for a great how-to, well done. I wish other sites were a clear and concise.
Eugene Carroll - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 27
Todo El Tiempo: 11,600
