Saltar al contenido principal
Asus Chromebook Flip C100 Lower Case Replacement
Qué necesitas
  1. Asus Chromebook Flip C100 Lower Case Replacement, Lower Case: paso 1, imagen 1 de 1
    • Unscrew the eight bottom cover screws (one of them is under the hand) using a screwdriver with a J1000 tip.
    • Unscrew the middle screw towards the top of the device using a screwdriver with a T5 tip.
  2. Asus Chromebook Flip C100 Lower Case Replacement: paso 2, imagen 1 de 1
    • Use the plastic opening tool to remove the four bottom rubber feet.
  3. Asus Chromebook Flip C100 Lower Case Replacement: paso 3, imagen 1 de 1
    • Unscrew the four screws under the feet using a screwdriver with a J100 tip.
  4. Asus Chromebook Flip C100 Lower Case Replacement: paso 4, imagen 1 de 1
    • Use the plastic opening tool to pry up the palm rest assembly.
  5. Asus Chromebook Flip C100 Lower Case Replacement: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Disconnect the two cables from the motherboard with tweezers
Conclusión
11 personas más completaron esta guía.
1Guía Comentario
great guide, though i found the nine screws on the outside required a t5 tip, while the 5 under the feet looked like they were either j100 or j1000, but a philips head worked.
Matthew Sylvester - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 22
Todo El Tiempo: 5,203
