Saltar al contenido principal
Asus Chromebook C523N Speaker Replacement
Qué necesitas
  1. Asus Chromebook C523N Speaker Replacement, Back Cover: paso 1, imagen 1 de 2 Asus Chromebook C523N Speaker Replacement, Back Cover: paso 1, imagen 2 de 2
    • Remove the four 0.5mm JIS #00 screws from the bottom edge of the Chromebook and one in the center.
    • Remove the six 1.7mm JIS #00 screws from the sides and top edge of the Chromebook.
  2. Asus Chromebook C523N Speaker Replacement: paso 2, imagen 1 de 2 Asus Chromebook C523N Speaker Replacement: paso 2, imagen 2 de 2
    • Using a spudger, lift the top left base pad and remove it to reveal a final screw underneath.
    • Remove the one 0.5mm JIS #00 screw underneath the base pad.
  3. Asus Chromebook C523N Speaker Replacement: paso 3, imagen 1 de 2 Asus Chromebook C523N Speaker Replacement: paso 3, imagen 2 de 2
    • Use an opening tool to gently pry the base enclosure up and remove from the laptop.
  4. Asus Chromebook C523N Speaker Replacement, Speaker: paso 4, imagen 1 de 3 Asus Chromebook C523N Speaker Replacement, Speaker: paso 4, imagen 2 de 3 Asus Chromebook C523N Speaker Replacement, Speaker: paso 4, imagen 3 de 3
    • Using the nylon tipped tweezers, gently pry the black and white wires from the wireless card and lift.
  5. Asus Chromebook C523N Speaker Replacement: paso 5, imagen 1 de 3 Asus Chromebook C523N Speaker Replacement: paso 5, imagen 2 de 3 Asus Chromebook C523N Speaker Replacement: paso 5, imagen 3 de 3
    • Use a spudger to pry the small tangle of black, red, white, and blue wires from the audio connector, pushing the wires back toward the speaker.
  6. Asus Chromebook C523N Speaker Replacement: paso 6, imagen 1 de 2 Asus Chromebook C523N Speaker Replacement: paso 6, imagen 2 de 2
    • Use a spudger to pry the black wire from the audio connector, pushing the wires back toward the left speaker.
  7. Asus Chromebook C523N Speaker Replacement: paso 7, imagen 1 de 1
    • Gently grab both speakers and lift them from the Chromebook to remove.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 550
