Introducción
The motherboard is extremely important to the overall function of your Asus Chromebook C523N. It is a printed circuit board that allows for the overall communication between many of the components, including the CPU, RAM, and many other hardwares.
Usually, the only other solution to an unresponsive motherboard is to buy an entirely new laptop. Without the hub of your laptop, most functions are nearly impossible.
Qué necesitas
Remove the four 0.5mm JIS #00 screws from the bottom edge of the Chromebook and one in the center.
Remove the six 1.7mm JIS #00 screws from the sides and top edge of the Chromebook.
To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small locking flap.
Gently disconnect the battery cable from the motherboard.
Using tweezers, gently pry the black and white wires from the wireless card and lift.
4 personas más completaron esta guía.
