Saltar al contenido principal
Asus Chromebook C523N Motherboard Replacement
Qué necesitas
  1. Asus Chromebook C523N Motherboard Replacement, Back Cover: paso 1, imagen 1 de 2 Asus Chromebook C523N Motherboard Replacement, Back Cover: paso 1, imagen 2 de 2
    • Remove the four 0.5mm JIS #00 screws from the bottom edge of the Chromebook and one in the center.
    • Remove the six 1.7mm JIS #00 screws from the sides and top edge of the Chromebook.
  2. Asus Chromebook C523N Motherboard Replacement: paso 2, imagen 1 de 2 Asus Chromebook C523N Motherboard Replacement: paso 2, imagen 2 de 2
    • Using a spudger, lift the top left base pad and remove it to reveal a final screw underneath.
    • Remove the one 0.5mm JIS #00 screw underneath the base pad.
  3. Asus Chromebook C523N Motherboard Replacement: paso 3, imagen 1 de 2 Asus Chromebook C523N Motherboard Replacement: paso 3, imagen 2 de 2
    • Use an opening tool to gently pry the base enclosure up and remove from the laptop.
  4. Asus Chromebook C523N Motherboard Replacement, Battery: paso 4, imagen 1 de 3 Asus Chromebook C523N Motherboard Replacement, Battery: paso 4, imagen 2 de 3 Asus Chromebook C523N Motherboard Replacement, Battery: paso 4, imagen 3 de 3
    • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small locking flap.
    • Gently disconnect the battery cable from the motherboard.
  5. Asus Chromebook C523N Motherboard Replacement: paso 5, imagen 1 de 2 Asus Chromebook C523N Motherboard Replacement: paso 5, imagen 2 de 2
    • Remove six 1.4 mm JIS #00 screws from the battery.
  6. Asus Chromebook C523N Motherboard Replacement: paso 6, imagen 1 de 1
    • Remove the battery from the laptop.
  7. Asus Chromebook C523N Motherboard Replacement, Motherboard: paso 7, imagen 1 de 3 Asus Chromebook C523N Motherboard Replacement, Motherboard: paso 7, imagen 2 de 3 Asus Chromebook C523N Motherboard Replacement, Motherboard: paso 7, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Using tweezers, gently pry the black and white wires from the wireless card and lift.
  8. Asus Chromebook C523N Motherboard Replacement: paso 8, imagen 1 de 3 Asus Chromebook C523N Motherboard Replacement: paso 8, imagen 2 de 3 Asus Chromebook C523N Motherboard Replacement: paso 8, imagen 3 de 3
    • Gently pull the trackpad cable from the connector, located next to the wireless card.
  9. Asus Chromebook C523N Motherboard Replacement: paso 9, imagen 1 de 3 Asus Chromebook C523N Motherboard Replacement: paso 9, imagen 2 de 3 Asus Chromebook C523N Motherboard Replacement: paso 9, imagen 3 de 3
    • Using a spudger, disconnect the two side-by-side ribbon cables from their connectors, pushing in the direction of the ribbons (toward the left side of the Chromebook).
  10. Asus Chromebook C523N Motherboard Replacement: paso 10, imagen 1 de 2 Asus Chromebook C523N Motherboard Replacement: paso 10, imagen 2 de 2
    • Disconnect the thick blue ribbon cable from the connector by pulling it away from the motherboard.
  11. Asus Chromebook C523N Motherboard Replacement: paso 11, imagen 1 de 3 Asus Chromebook C523N Motherboard Replacement: paso 11, imagen 2 de 3 Asus Chromebook C523N Motherboard Replacement: paso 11, imagen 3 de 3
    • Remove the 0.4mm JIS #0 screws from the heat sink in the center of the motherboard.
    • Lift and remove the heat sink.
  12. Asus Chromebook C523N Motherboard Replacement: paso 12, imagen 1 de 3 Asus Chromebook C523N Motherboard Replacement: paso 12, imagen 2 de 3 Asus Chromebook C523N Motherboard Replacement: paso 12, imagen 3 de 3
    • Gripping the thin white ribbon cable, gently pull it away from the motherboard to disconnect.
  13. Asus Chromebook C523N Motherboard Replacement: paso 13, imagen 1 de 2 Asus Chromebook C523N Motherboard Replacement: paso 13, imagen 2 de 2
    • Disconnect the thick black connector by gently pulling it up, away from the motherboard.
  14. Asus Chromebook C523N Motherboard Replacement: paso 14, imagen 1 de 2 Asus Chromebook C523N Motherboard Replacement: paso 14, imagen 2 de 2
    • Remove the two 0.4mm JIS #00 screws at the bottom of the hinge (closest to the motherboard).
    • Using an opening tool, pry the hinge upward.
  15. Asus Chromebook C523N Motherboard Replacement: paso 15, imagen 1 de 2 Asus Chromebook C523N Motherboard Replacement: paso 15, imagen 2 de 2
    • Remove the two 0.4 mm JIS #00 screws from the motherboard.
    • Gently lift and remove the motherboard.
Conclusión
4 personas más completaron esta guía.
2 comentarios
Hi!
I assembled the motherboard but it isn't working. There is no power light. How to validate that the motherboard is functioning?
If I just connect power stream to its USBC power port the LED should be lighting?
mmm - Contestar
I was following this guide and I found there were actually four screws holding the MB down. The red/blue/white/black speaker cable must also be disconnected to get the board out entirely.
Jaret Meier - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 48
Todo El Tiempo: 3,655
