Saltar al contenido principal
Asus Chromebook C300SA-DS02 VECO Speakers Replacement
Qué necesitas
  1. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement, Keyboard: paso 1, imagen 1 de 2 Asus Chromebook C300SA-DS02 VECO Speakers  Replacement, Keyboard: paso 1, imagen 2 de 2
    • Power the laptop off and make sure the charger is unplugged before starting.
    • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
    • Remove the three 6.0mm Phillips #0 screws.
  2. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: paso 2, imagen 1 de 3 Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: paso 2, imagen 2 de 3 Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: paso 2, imagen 3 de 3
    • Open the laptop.
    • Using an iFixit opening tool, pry along the edges of the keyboard.
    • Lift the keyboard and slide it gently towards you.
    • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
  3. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: paso 3, imagen 1 de 3 Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: paso 3, imagen 2 de 3 Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: paso 3, imagen 3 de 3
    • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
  4. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: paso 4, imagen 1 de 1
    • Remove the keyboard from the laptop.
  5. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement, Battery: paso 5, imagen 1 de 2 Asus Chromebook C300SA-DS02 VECO Speakers  Replacement, Battery: paso 5, imagen 2 de 2
    • Remove the six 5.6mm Phillips #0 screws around the battery.
  6. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: paso 6, imagen 1 de 2 Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: paso 6, imagen 2 de 2
    • Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
  7. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: paso 7, imagen 1 de 1
    • Lift the battery out of the laptop.
  8. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement, VECO Speakers: paso 8, imagen 1 de 1
    • Unplug the speaker cable from the motherboard.
  9. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: paso 9, imagen 1 de 2 Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: paso 9, imagen 2 de 2
    • Start by removing the right speaker first.
    • There are two metal clips and one plastic clip holding the right speaker in place. Push them back and lift speaker out of the laptop.
    • Use a screwdriver to gently push back the metal clips.
  10. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: paso 10, imagen 1 de 2 Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: paso 10, imagen 2 de 2
    • Untangle the wire connecting the right speaker to the left speaker.
    • Move right speaker and wires away from your working space.
    • Do not lift wire straight up, there are five interlocking ribs holding this wire in place.
  11. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: paso 11, imagen 1 de 1
    • You can use a screwdriver to push back the clips if needed.
  12. Asus Chromebook C300SA-DS02 VECO Speakers  Replacement: paso 12, imagen 1 de 1
    • Lift speakers and cable away from the laptop.
Conclusión
Una persona más ha completado esta guía.
Sam LaBelle
Miembro Desde 10/17/17
107 Reputación
1 Guía escrita
Equipo
UMass Dartmouth, Team S1-G7, Simcock Fall 2017 Miembro de UMass Dartmouth, Team S1-G7, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G7
Miembros de 3
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 376
