Saltar al contenido principal
Asus Chromebook C300SA-DS02 LED Screen Replacement
Qué necesitas
  1. Asus Chromebook C300SA-DS02 LED Screen Replacement, Keyboard: paso 1, imagen 1 de 2 Asus Chromebook C300SA-DS02 LED Screen Replacement, Keyboard: paso 1, imagen 2 de 2
    • Power the laptop off and make sure the charger is unplugged before starting.
    • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
    • Remove the three 6.0mm Phillips #0 screws.
  2. Asus Chromebook C300SA-DS02 LED Screen Replacement: paso 2, imagen 1 de 3 Asus Chromebook C300SA-DS02 LED Screen Replacement: paso 2, imagen 2 de 3 Asus Chromebook C300SA-DS02 LED Screen Replacement: paso 2, imagen 3 de 3
    • Open the laptop.
    • Using an iFixit opening tool, pry along the edges of the keyboard.
    • Lift the keyboard and slide it gently towards you.
    • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
  3. Asus Chromebook C300SA-DS02 LED Screen Replacement: paso 3, imagen 1 de 3 Asus Chromebook C300SA-DS02 LED Screen Replacement: paso 3, imagen 2 de 3 Asus Chromebook C300SA-DS02 LED Screen Replacement: paso 3, imagen 3 de 3
    • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
  4. Asus Chromebook C300SA-DS02 LED Screen Replacement: paso 4, imagen 1 de 1
    • Remove the keyboard from the laptop.
  5. Asus Chromebook C300SA-DS02 LED Screen Replacement, Battery: paso 5, imagen 1 de 2 Asus Chromebook C300SA-DS02 LED Screen Replacement, Battery: paso 5, imagen 2 de 2
    • Remove the six 5.6mm Phillips #0 screws around the battery.
  6. Asus Chromebook C300SA-DS02 LED Screen Replacement: paso 6, imagen 1 de 2 Asus Chromebook C300SA-DS02 LED Screen Replacement: paso 6, imagen 2 de 2
    • Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
  7. Asus Chromebook C300SA-DS02 LED Screen Replacement: paso 7, imagen 1 de 1
    • Lift the battery out of the laptop.
  8. Asus Chromebook C300SA-DS02 LED Screen Replacement, LED Screen: paso 8, imagen 1 de 2 Asus Chromebook C300SA-DS02 LED Screen Replacement, LED Screen: paso 8, imagen 2 de 2
    • Unplug the black and white cable from the motherboard.
    • These two wires connect to the antenna within the display assembly. The white cable is longer and connects to the bottom import.
  9. Asus Chromebook C300SA-DS02 LED Screen Replacement: paso 9, imagen 1 de 1
    • Peel back the tape covering the plug.
    • Slide the cable towards the screen and out of the input.
  10. Asus Chromebook C300SA-DS02 LED Screen Replacement: paso 10, imagen 1 de 1
    • Unscrew the 6 screws (5 millimeter) on the top right and left.
  11. Asus Chromebook C300SA-DS02 LED Screen Replacement: paso 11, imagen 1 de 1
    • Gently lift the screen up and away from the laptop.
  12. Asus Chromebook C300SA-DS02 LED Screen Replacement: paso 12, imagen 1 de 1
    • Pry off the face panel on the screen using the blue prying tool.
  13. Asus Chromebook C300SA-DS02 LED Screen Replacement: paso 13, imagen 1 de 1
    • Remove the four 2mm Phillips #0 screws from the four corners of the screen.
  14. Asus Chromebook C300SA-DS02 LED Screen Replacement: paso 14, imagen 1 de 2 Asus Chromebook C300SA-DS02 LED Screen Replacement: paso 14, imagen 2 de 2
    • Gently lift screen
    • Peel back the adhesive covering the cable.
    • Remove the cable to free the screen.
Conclusión
Una persona más ha completado esta guía.
Celina Monteiro
Miembro Desde 10/17/17
224 Reputación
2 Guías creadas
Equipo
Un comentario
I used this honestly I broke the screen and some of the wires in the screen are severed. Now I know for sure where the wires go and how to deconstruct it. Thank you so much!
Glorybringers Child - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 697
