Saltar al contenido principal
Asus Chromebook C300SA- DS02 Battery Replacement
Qué necesitas
  1. Asus Chromebook C300SA- DS02 Battery Replacement, Keyboard: paso 1, imagen 1 de 2 Asus Chromebook C300SA- DS02 Battery Replacement, Keyboard: paso 1, imagen 2 de 2
    • Power the laptop off and make sure the charger is unplugged before starting.
    • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
    • Remove the three 6.0mm Phillips #0 screws.
  2. Asus Chromebook C300SA- DS02 Battery Replacement: paso 2, imagen 1 de 3 Asus Chromebook C300SA- DS02 Battery Replacement: paso 2, imagen 2 de 3 Asus Chromebook C300SA- DS02 Battery Replacement: paso 2, imagen 3 de 3
    • Open the laptop.
    • Using an iFixit opening tool, pry along the edges of the keyboard.
    • Lift the keyboard and slide it gently towards you.
    • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
  3. Asus Chromebook C300SA- DS02 Battery Replacement: paso 3, imagen 1 de 3 Asus Chromebook C300SA- DS02 Battery Replacement: paso 3, imagen 2 de 3 Asus Chromebook C300SA- DS02 Battery Replacement: paso 3, imagen 3 de 3
    • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
  4. Asus Chromebook C300SA- DS02 Battery Replacement: paso 4, imagen 1 de 1
    • Remove the keyboard from the laptop.
  5. Asus Chromebook C300SA- DS02 Battery Replacement, Battery: paso 5, imagen 1 de 2 Asus Chromebook C300SA- DS02 Battery Replacement, Battery: paso 5, imagen 2 de 2
    • Remove the six 5.6mm Phillips #0 screws around the battery.
  6. Asus Chromebook C300SA- DS02 Battery Replacement: paso 6, imagen 1 de 2 Asus Chromebook C300SA- DS02 Battery Replacement: paso 6, imagen 2 de 2
    • Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
  7. Asus Chromebook C300SA- DS02 Battery Replacement: paso 7, imagen 1 de 1
    • Lift the battery out of the laptop.
Conclusión
2 personas más completaron esta guía.
Equipo
UMass Dartmouth, Team S1-G7, Simcock Fall 2017 Miembro de UMass Dartmouth, Team S1-G7, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G7
Miembros de 3
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 994
