Saltar al contenido principal
Asus Chromebook C300MA-EDU Thermal Paste Replacement
Qué necesitas
  1. Asus Chromebook C300MA-EDU Thermal Paste Replacement, Keyboard: paso 1, imagen 1 de 2 Asus Chromebook C300MA-EDU Thermal Paste Replacement, Keyboard: paso 1, imagen 2 de 2
    • Flip the Chromebook onto its back, where there are eleven screws.
    • There are two variations of screws on the back panel:
    • Six 8.7mm screws.
    • Five 6.4mm screws.
    • Using your screwdriver with the J00 Phillips Head tip, remove the screws by turning them counter clockwise.
  2. Asus Chromebook C300MA-EDU Thermal Paste Replacement: paso 2, imagen 1 de 2 Asus Chromebook C300MA-EDU Thermal Paste Replacement: paso 2, imagen 2 de 2
    • Once the screws are removed, flip the Chromebook back over.
    • Gently remove the keyboard by starting to lift up on one corner with a plastic opening tool.
    • Follow around the brim of the keyboard until it pops off.
  3. Asus Chromebook C300MA-EDU Thermal Paste Replacement: paso 3, imagen 1 de 3 Asus Chromebook C300MA-EDU Thermal Paste Replacement: paso 3, imagen 2 de 3 Asus Chromebook C300MA-EDU Thermal Paste Replacement: paso 3, imagen 3 de 3
    • Once you remove the keyboard, it will be connected to the CPU with two tabbed connections.
    • Release the connections from the tabs gently by flipping the white flaps up until disconnected.
    • You can now pull the ribbons out from the board and remove the keyboard.
  4. Asus Chromebook C300MA-EDU Thermal Paste Replacement, Battery: paso 4, imagen 1 de 3 Asus Chromebook C300MA-EDU Thermal Paste Replacement, Battery: paso 4, imagen 2 de 3 Asus Chromebook C300MA-EDU Thermal Paste Replacement, Battery: paso 4, imagen 3 de 3
    • Once the keyboard is removed, the battery is located on the bottom portion of the shell.
    • The battery is held in with six 6.5mm screws on opposing sides.
  5. Asus Chromebook C300MA-EDU Thermal Paste Replacement: paso 5, imagen 1 de 2 Asus Chromebook C300MA-EDU Thermal Paste Replacement: paso 5, imagen 2 de 2
    • The battery is now held in with a tabbed connection to the CPU on the left side of the board. On the tabbed connection, there is a silver plate.
    • Gently push on the silver plate towards the screen until the plastic connection is free.
    • The tabbed connection should now slide out backwards.
  6. Asus Chromebook C300MA-EDU Thermal Paste Replacement: paso 6, imagen 1 de 2 Asus Chromebook C300MA-EDU Thermal Paste Replacement: paso 6, imagen 2 de 2
    • At this point, using the plastic removal tool, lift the battery out of the shell.
  7. Asus Chromebook C300MA-EDU Thermal Paste Replacement, Thermal Paste: paso 7, imagen 1 de 3 Asus Chromebook C300MA-EDU Thermal Paste Replacement, Thermal Paste: paso 7, imagen 2 de 3 Asus Chromebook C300MA-EDU Thermal Paste Replacement, Thermal Paste: paso 7, imagen 3 de 3
    • The metal plate is held in by two 3.4mm Phillip head screws.
    • Remove them by turning the screws counter clockwise.
    • Lift the plate off using a plastic opening tool or by hand.
  8. Asus Chromebook C300MA-EDU Thermal Paste Replacement: paso 8, imagen 1 de 3 Asus Chromebook C300MA-EDU Thermal Paste Replacement: paso 8, imagen 2 de 3 Asus Chromebook C300MA-EDU Thermal Paste Replacement: paso 8, imagen 3 de 3
    • The existing thermal paste should now be exposed.
    • Using a paper towel, gently wipe off the existing thermal paste from both the CPU and the metal cover.
  9. Asus Chromebook C300MA-EDU Thermal Paste Replacement: paso 9, imagen 1 de 3 Asus Chromebook C300MA-EDU Thermal Paste Replacement: paso 9, imagen 2 de 3 Asus Chromebook C300MA-EDU Thermal Paste Replacement: paso 9, imagen 3 de 3
    • Once you remove the residue, apply a small amount of thermal paste in one area on the CPU.
    • The amount of thermal paste applied should be the size of a circle with a diameter of 2mm.
    • Applying too much thermal paste may result in the system not ventilating properly, leading to overheating issues.
    • Place metal plate back on. This will naturally spread the thermal paste across the CPU.
    • The thermal paste is now replaced.
Conclusión
Equipo
USF Tampa, Team S2-G3, Nance Fall 2017 Miembro de USF Tampa, Team S2-G3, Nance Fall 2017
USFT-NANCE-F17S2G3
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 635
