Saltar al contenido principal
Asus Chromebook C300MA-EDU Keyboard Replacement
Qué necesitas
  1. Asus Chromebook C300MA-EDU Keyboard Replacement, Keyboard: paso 1, imagen 1 de 2 Asus Chromebook C300MA-EDU Keyboard Replacement, Keyboard: paso 1, imagen 2 de 2
    • Flip the Chromebook onto its back, where there are eleven screws.
    • There are two variations of screws on the back panel:
    • Six 8.7mm screws.
    • Five 6.4mm screws.
    • Using your screwdriver with the J00 Phillips Head tip, remove the screws by turning them counter clockwise.
  2. Asus Chromebook C300MA-EDU Keyboard Replacement: paso 2, imagen 1 de 2 Asus Chromebook C300MA-EDU Keyboard Replacement: paso 2, imagen 2 de 2
    • Once the screws are removed, flip the Chromebook back over.
    • Gently remove the keyboard by starting to lift up on one corner with a plastic opening tool.
    • Follow around the brim of the keyboard until it pops off.
  3. Asus Chromebook C300MA-EDU Keyboard Replacement: paso 3, imagen 1 de 3 Asus Chromebook C300MA-EDU Keyboard Replacement: paso 3, imagen 2 de 3 Asus Chromebook C300MA-EDU Keyboard Replacement: paso 3, imagen 3 de 3
    • Once you remove the keyboard, it will be connected to the CPU with two tabbed connections.
    • Release the connections from the tabs gently by flipping the white flaps up until disconnected.
    • You can now pull the ribbons out from the board and remove the keyboard.
Conclusión
Equipo
USF Tampa, Team S2-G3, Nance Fall 2017 Miembro de USF Tampa, Team S2-G3, Nance Fall 2017
USFT-NANCE-F17S2G3
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 692
