Saltar al contenido principal
Asus Chromebook C300MA-DH02 Trackpad Replacement
Qué necesitas
  1. Asus Chromebook C300MA-DH02 Trackpad Replacement, Keyboard Panel: paso 1, imagen 1 de 3 Asus Chromebook C300MA-DH02 Trackpad Replacement, Keyboard Panel: paso 1, imagen 2 de 3 Asus Chromebook C300MA-DH02 Trackpad Replacement, Keyboard Panel: paso 1, imagen 3 de 3
    • Flip the Chromebook over so that the underside is facing up.
    • Using the Phillips PH #000 screwdriver, remove the 11 "4mm" screws on the back of the device.
  2. Asus Chromebook C300MA-DH02 Trackpad Replacement: paso 2, imagen 1 de 1
    • Wedge the plastic opening tool between the bottom cover of the laptop and the keyboard panel.
    • Apply pressure and move the plastic opening tool around the border of the laptop until it pops out.
  3. Asus Chromebook C300MA-DH02 Trackpad Replacement: paso 3, imagen 1 de 2 Asus Chromebook C300MA-DH02 Trackpad Replacement: paso 3, imagen 2 de 2
    • Once the keyboard panel pops out, slowly move it upwards so that the keyboard connection is visible.
    • Remove the keyboard connection from the motherboard by pulling it outwards from the connector.
  4. Asus Chromebook C300MA-DH02 Trackpad Replacement, Trackpad: paso 4, imagen 1 de 2 Asus Chromebook C300MA-DH02 Trackpad Replacement, Trackpad: paso 4, imagen 2 de 2
    • Unplug the blue wire that connects trackpad to the keyboard.
  5. Asus Chromebook C300MA-DH02 Trackpad Replacement: paso 5, imagen 1 de 1
    • Remove the aluminum tape that secures the trackpad. Use tweezers if necessary.
  6. Asus Chromebook C300MA-DH02 Trackpad Replacement: paso 6, imagen 1 de 2 Asus Chromebook C300MA-DH02 Trackpad Replacement: paso 6, imagen 2 de 2
    • Using the Phillips #000 screwdriver, remove the (4) four "4 mm" screws that secure trackpad onto keyboard.
  7. Asus Chromebook C300MA-DH02 Trackpad Replacement: paso 7, imagen 1 de 2 Asus Chromebook C300MA-DH02 Trackpad Replacement: paso 7, imagen 2 de 2
    • Using a plastic opening tool, pry out the touchpad from the metal securing bracket.
Conclusión
2 personas más completaron esta guía.
Raaefazer
Miembro Desde 10/02/17
131 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S6-G4, Remmell Fall 2017 Miembro de USF Tampa, Team S6-G4, Remmell Fall 2017
USFT-REMMELL-F17S6G4
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 188
