Saltar al contenido principal
Asus Chromebook C300MA-DH02 Keyboard Panel Replacement
Qué necesitas
  1. Asus Chromebook C300MA-DH02 Keyboard Panel Replacement, Keyboard Panel: paso 1, imagen 1 de 3 Asus Chromebook C300MA-DH02 Keyboard Panel Replacement, Keyboard Panel: paso 1, imagen 2 de 3 Asus Chromebook C300MA-DH02 Keyboard Panel Replacement, Keyboard Panel: paso 1, imagen 3 de 3
    • Flip the Chromebook over so that the underside is facing up.
    • Using the Phillips PH #000 screwdriver, remove the 11 "4mm" screws on the back of the device.
  2. Asus Chromebook C300MA-DH02 Keyboard Panel Replacement: paso 2, imagen 1 de 1
    • Wedge the plastic opening tool between the bottom cover of the laptop and the keyboard panel.
    • Apply pressure and move the plastic opening tool around the border of the laptop until it pops out.
  3. Asus Chromebook C300MA-DH02 Keyboard Panel Replacement: paso 3, imagen 1 de 2 Asus Chromebook C300MA-DH02 Keyboard Panel Replacement: paso 3, imagen 2 de 2
    • Once the keyboard panel pops out, slowly move it upwards so that the keyboard connection is visible.
    • Remove the keyboard connection from the motherboard by pulling it outwards from the connector.
Conclusión
Juan Pericas
Miembro Desde 10/02/17
101 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S6-G4, Remmell Fall 2017 Miembro de USF Tampa, Team S6-G4, Remmell Fall 2017
USFT-REMMELL-F17S6G4
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 147
