Saltar al contenido principal
Asus Chromebook C300MA-DH02 Display Replacement
Qué necesitas
  1. Asus Chromebook C300MA-DH02 Display Replacement, Keyboard Panel: paso 1, imagen 1 de 3 Asus Chromebook C300MA-DH02 Display Replacement, Keyboard Panel: paso 1, imagen 2 de 3 Asus Chromebook C300MA-DH02 Display Replacement, Keyboard Panel: paso 1, imagen 3 de 3
    • Flip the Chromebook over so that the underside is facing up.
    • Using the Phillips PH #000 screwdriver, remove the 11 "4mm" screws on the back of the device.
  2. Asus Chromebook C300MA-DH02 Display Replacement: paso 2, imagen 1 de 1
    • Wedge the plastic opening tool between the bottom cover of the laptop and the keyboard panel.
    • Apply pressure and move the plastic opening tool around the border of the laptop until it pops out.
  3. Asus Chromebook C300MA-DH02 Display Replacement: paso 3, imagen 1 de 2 Asus Chromebook C300MA-DH02 Display Replacement: paso 3, imagen 2 de 2
    • Once the keyboard panel pops out, slowly move it upwards so that the keyboard connection is visible.
    • Remove the keyboard connection from the motherboard by pulling it outwards from the connector.
  4. Asus Chromebook C300MA-DH02 Display Replacement, Display: paso 4, imagen 1 de 2 Asus Chromebook C300MA-DH02 Display Replacement, Display: paso 4, imagen 2 de 2
    • Remove the hinge protector by using the plastic opening tool to gently lift it up. It should come up easily.
  5. Asus Chromebook C300MA-DH02 Display Replacement: paso 5, imagen 1 de 2 Asus Chromebook C300MA-DH02 Display Replacement: paso 5, imagen 2 de 2
    • Using the plastic opening tool, separate the display cover bracket from the back of the display. Start from the top.
  6. Asus Chromebook C300MA-DH02 Display Replacement: paso 6, imagen 1 de 2 Asus Chromebook C300MA-DH02 Display Replacement: paso 6, imagen 2 de 2
    • Remove the (4) four "4mm" screws in each corner that hold the display using the Phillips #000 screwdriver.
  7. Asus Chromebook C300MA-DH02 Display Replacement: paso 7, imagen 1 de 1
    • Lower the display to allow access to connector in back.
  8. Asus Chromebook C300MA-DH02 Display Replacement: paso 8, imagen 1 de 2 Asus Chromebook C300MA-DH02 Display Replacement: paso 8, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Lift the tape covering the connector with the tweezers.
    • Gently remove the display connector from the motherboard.
Conclusión
Zachary Leonard
Miembro Desde 10/02/17
304 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S6-G4, Remmell Fall 2017 Miembro de USF Tampa, Team S6-G4, Remmell Fall 2017
USFT-REMMELL-F17S6G4
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 228
