Saltar al contenido principal
Asus Chromebook C300MA-DB01 Screen Replacement
Qué necesitas
  1. Asus Chromebook C300MA-DB01 Screen Replacement, Screen: paso 1, imagen 1 de 2 Asus Chromebook C300MA-DB01 Screen Replacement, Screen: paso 1, imagen 2 de 2
    • Use plastic opening tool to remove the frame around the screen. It is recommended to start in the upper corners.
  2. Asus Chromebook C300MA-DB01 Screen Replacement: paso 2, imagen 1 de 2 Asus Chromebook C300MA-DB01 Screen Replacement: paso 2, imagen 2 de 2
    • Use plastic opening tool to remove plastic hinge casing located between the screen and keyboard.
  3. Asus Chromebook C300MA-DB01 Screen Replacement: paso 3, imagen 1 de 1
    • Use 64 bitdriver to remove 4 6.0 mm Phillips screws from screen the screws that need to be removed are located in the corners of the screen.
  4. Asus Chromebook C300MA-DB01 Screen Replacement: paso 4, imagen 1 de 1
    • Use plastic prying tool to detach the wire that connects the screen to the lower non-display half of the laptop.
  5. Asus Chromebook C300MA-DB01 Screen Replacement: paso 5, imagen 1 de 1
    • Lift and remove screen from the laptop.
Conclusión
wyatt boyatt
Miembro Desde 09/25/17
541 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S4-G3, Eyestone Fall 2017 Miembro de USF Tampa, Team S4-G3, Eyestone Fall 2017
USFT-EYESTONE-F17S4G3
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 314
