Saltar al contenido principal
Asus Chromebook C300MA-BBCLN12 Keyboard Replacement
Qué necesitas
  1. Asus Chromebook C300MA-BBCLN12 Keyboard Replacement, Keyboard: paso 1, imagen 1 de 3 Asus Chromebook C300MA-BBCLN12 Keyboard Replacement, Keyboard: paso 1, imagen 2 de 3 Asus Chromebook C300MA-BBCLN12 Keyboard Replacement, Keyboard: paso 1, imagen 3 de 3
    • Remove the eight 9.0mm PH00 Phillips screws along the perimeter of the bottom housing.
    • Remove the three 6.0mm PH00 Phillips screws from the center of the bottom housing.
  2. Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: paso 2, imagen 1 de 3 Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: paso 2, imagen 2 de 3 Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: paso 2, imagen 3 de 3
    • Separate the palm rest assembly from the bottom housing using the plastic opening tool.
    • It is recommended that you start from a corner and run the tip of the plastic opening tool along the edge of the housing.
    • Lift the palm rest assembly slowly to prevent damaging the two cables connecting it to the motherboard.
  3. Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: paso 3, imagen 1 de 3 Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: paso 3, imagen 2 de 3 Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Flip back the hinges on the connectors that secure the wide black cable and the narrow white cable using the tweezers.
    • Disconnect the wide black cable from the motherboard by pulling the blue cable tab straight out of the connector.
    • Disconnect the white ribbon cable from the motherboard by pulling the blue cable tab straight out of the connector.
  4. Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: paso 4, imagen 1 de 3 Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: paso 4, imagen 2 de 3 Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: paso 4, imagen 3 de 3
    • Flip back the hinge on the connector that secures the white ribbon cable to the underside of the palm rest assembly using the tweezers.
    • Disconnect the white ribbon cable from the palm rest assembly by pulling the cable straight out of the connector.
  5. Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: paso 5, imagen 1 de 3 Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: paso 5, imagen 2 de 3 Asus Chromebook C300MA-BBCLN12 Keyboard Replacement: paso 5, imagen 3 de 3
    • Remove the palm rest assembly from the bottom housing and lay it on a flat surface with the keyboard facing downward.
    • Remove the four 5.0mm PH00 Phillips screws securing the keyboard to the palm rest assembly.
    • Separate the keyboard from the palm rest assembly.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 426
