Saltar al contenido principal
Asus Chromebook C300MA-BBCLN12 Battery Replacement
Qué necesitas
  1. Asus Chromebook C300MA-BBCLN12 Battery Replacement, Battery: paso 1, imagen 1 de 2 Asus Chromebook C300MA-BBCLN12 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the eight 9.0mm Phillips #00 screws.
    • Remove the three 6.0mm Phillips #00 screws.
  2. Asus Chromebook C300MA-BBCLN12 Battery Replacement: paso 2, imagen 1 de 3 Asus Chromebook C300MA-BBCLN12 Battery Replacement: paso 2, imagen 2 de 3 Asus Chromebook C300MA-BBCLN12 Battery Replacement: paso 2, imagen 3 de 3
    • Separate the palm rest assembly from the bottom housing using the plastic opening tool.
    • It is recommended that you start from a corner and run the plastic opening tool along the edge of the housing.
    • Lift the palm rest assembly slowly to prevent damaging the two cables that connect it to the motherboard.
  3. Asus Chromebook C300MA-BBCLN12 Battery Replacement: paso 3, imagen 1 de 3 Asus Chromebook C300MA-BBCLN12 Battery Replacement: paso 3, imagen 2 de 3 Asus Chromebook C300MA-BBCLN12 Battery Replacement: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Flip back the hinges on the connectors that secure the wide black cable and the narrow white cable using the tweezers.
    • Disconnect the wide black cable from the motherboard by pulling the blue cable tab away from the connector.
    • Disconnect the white ribbon cable from the motherboard by pulling the blue cable tab away from the connector.
  4. Asus Chromebook C300MA-BBCLN12 Battery Replacement: paso 4, imagen 1 de 1
    • Remove the six 6.0mm Phillips #00 screws that secure the battery to the bottom housing.
  5. Asus Chromebook C300MA-BBCLN12 Battery Replacement: paso 5, imagen 1 de 2 Asus Chromebook C300MA-BBCLN12 Battery Replacement: paso 5, imagen 2 de 2
    • Disconnect the bundled cable connector that attaches the battery to the motherboard using the small plastic spudger.
  6. Asus Chromebook C300MA-BBCLN12 Battery Replacement: paso 6, imagen 1 de 1
    • Remove the battery from the bottom housing.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 441
