Saltar al contenido principal
Asus Chromebook C300MA DB01 Screen Replacement
Qué necesitas
  1. Asus Chromebook C300MA DB01 Screen Replacement, Screen: paso 1, imagen 1 de 3 Asus Chromebook C300MA DB01 Screen Replacement, Screen: paso 1, imagen 2 de 3 Asus Chromebook C300MA DB01 Screen Replacement, Screen: paso 1, imagen 3 de 3
    • Use a Jimmy to pry off the hinge cover from the screen.
  2. Asus Chromebook C300MA DB01 Screen Replacement: paso 2, imagen 1 de 2 Asus Chromebook C300MA DB01 Screen Replacement: paso 2, imagen 2 de 2
    • Run the Jimmy along the edges of the screen frame to unsnap it from the connectors.
    • Remove the screen frame manually.
  3. Asus Chromebook C300MA DB01 Screen Replacement: paso 3, imagen 1 de 3 Asus Chromebook C300MA DB01 Screen Replacement: paso 3, imagen 2 de 3 Asus Chromebook C300MA DB01 Screen Replacement: paso 3, imagen 3 de 3
    • Use a Phillips #1 screwdriver to remove the four screws on each corner of the screen.
    • Separate the screen from the top of the Chromebook with the Jimmy.
    • Avoid pulling the screen too far from the device as this can disconnect the wire located at the bottom of the screen.
    • Use the Jimmy to lift the latch on the wire jack.
    • Remove the wires and detach the screen from the device manually.
Conclusión
Earl Gill IV
Miembro Desde 04/01/19
193 Reputación
2 Guías creadas
Equipo
IUPUI, Team S10-G10, Wilson Spring 2019 Miembro de IUPUI, Team S10-G10, Wilson Spring 2019
IUPUI-WILSON-S19S10G10
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 114
