Saltar al contenido principal
Asus Chromebook C300MA DB01 Battery Replacement
Qué necesitas
  1. Asus Chromebook C300MA DB01 Battery Replacement, Removing the Back Cover: paso 1, imagen 1 de 1
    • Remove the eight 9.0 mm Phillips screws along the perimeter of the case.
    • Remove the three 6.0 mm Phillips screws from the center of the case.
  2. Asus Chromebook C300MA DB01 Battery Replacement, Taking off the Keyboard: paso 2, imagen 1 de 2 Asus Chromebook C300MA DB01 Battery Replacement, Taking off the Keyboard: paso 2, imagen 2 de 2
    • Slide the Jimmy in between the keyboard and underside of the laptop to remove the keyboard.
    • Leave the keyboard face down on the screen.
    • Do not pull the keyboard away from the laptop. The keyboard will still be attached with wires.
  3. Asus Chromebook C300MA DB01 Battery Replacement, Detaching keyboard: paso 3, imagen 1 de 2 Asus Chromebook C300MA DB01 Battery Replacement, Detaching keyboard: paso 3, imagen 2 de 2
    • Use a nylon spudger to lift the latch on each wire jack and detach the keyboard wires.
    • After the tabs have been lifted, the wire can be gently pulled out by hand.
    • Set the keyboard aside.
  4. Asus Chromebook C300MA DB01 Battery Replacement, Removing the battery: paso 4, imagen 1 de 3 Asus Chromebook C300MA DB01 Battery Replacement, Removing the battery: paso 4, imagen 2 de 3 Asus Chromebook C300MA DB01 Battery Replacement, Removing the battery: paso 4, imagen 3 de 3
    • Remove the six 6.0mm Phillips screws on the battery.
    • Remove the wire jack from the battery. Use a nylon spudger to lift the latch.
    • Remove the battery from the device.
Conclusión
Earl Gill IV
Miembro Desde 04/01/19
193 Reputación
2 Guías creadas
Equipo
IUPUI, Team S10-G10, Wilson Spring 2019 Miembro de IUPUI, Team S10-G10, Wilson Spring 2019
IUPUI-WILSON-S19S10G10
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 197
