Saltar al contenido principal
Asus Chromebook C300M USB Port Replacement
Qué necesitas
  1. Asus Chromebook C300M USB Port Replacement, USB Port: paso 1, imagen 1 de 2 Asus Chromebook C300M USB Port Replacement, USB Port: paso 1, imagen 2 de 2
    • Flip the chromebook on its front.
    • Remove the screws on the back using the Phillips #1 screwdriver.
    • Remove the six 8mm screws.
    • Remove the five 5mm screws.
  2. Asus Chromebook C300M USB Port Replacement: paso 2, imagen 1 de 1
    • Separate the plastic case from the keyboard at the seam using a plastic opening tool.
  3. Asus Chromebook C300M USB Port Replacement: paso 3, imagen 1 de 2 Asus Chromebook C300M USB Port Replacement: paso 3, imagen 2 de 2
    • Fully separate the plastic case from the keyboard by lifting it upward.
  4. Asus Chromebook C300M USB Port Replacement: paso 4, imagen 1 de 2 Asus Chromebook C300M USB Port Replacement: paso 4, imagen 2 de 2
    • The small and wide ribbon cables connect the keyboard to the motherboard.
    • Disconnect the small ribbon cable by lifting the flap and sliding it out of the motherboard input toward the battery using a spudger.
    • Disconnect the wide ribbon cable by lifting the flap and sliding it out of the motherboard input toward the battery using a spudger.
  5. Asus Chromebook C300M USB Port Replacement: paso 5, imagen 1 de 2 Asus Chromebook C300M USB Port Replacement: paso 5, imagen 2 de 2
    • Disconnect the USB port in the top right corner from the motherboard.
    • Unplug the the wide ribbon cable using spudger.
  6. Asus Chromebook C300M USB Port Replacement: paso 6, imagen 1 de 2 Asus Chromebook C300M USB Port Replacement: paso 6, imagen 2 de 2
    • Remove the single 3mm screw on the left and bottom side of the USB Port using the Phillips #1 screwdriver.
    • Remove the three 5mm screws on the upper part of the USB port with the same screwdriver.
    • Lift the edge of the white casing. Remove the USB Port by pulling it toward the bottom of the laptop.
Conclusión
2 personas más completaron esta guía.
Rachel Cadle
Miembro Desde 04/02/19
259 Reputación
2 Guías creadas
Equipo
IUPUI, Team S3-G2, Harley Spring 2019 Miembro de IUPUI, Team S3-G2, Harley Spring 2019
IUPUI-HARLEY-S19S3G2
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 744
