Saltar al contenido principal
Asus Chromebook C202SA-YS02 Camera Replacement
Qué necesitas
  1. Asus Chromebook C202SA-YS02 Camera Replacement, Bezel: paso 1, imagen 1 de 1
    • Using a flat blade, remove the two screw covers on the front of the bezel. They are attached by adhesive, so you may have to dig at it a little bit.
  2. Asus Chromebook C202SA-YS02 Camera Replacement: paso 2, imagen 1 de 1
    • Unscrew and remove the two Phillips #1 4.5 mm screws that are now visible.
  3. Asus Chromebook C202SA-YS02 Camera Replacement: paso 3, imagen 1 de 1
    • Using the plastic opening tool, carefully pry off the bezel. It will come off entirely, so be careful not to break it.
  4. Asus Chromebook C202SA-YS02 Camera Replacement, Camera: paso 4, imagen 1 de 1
    • Using the spudger, disconnect the cable from the camera. The camera will then pop out.
Conclusión
Beau Hansen
Miembro Desde 09/28/17
845 Reputación
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 22
Todo El Tiempo: 817
