Saltar al contenido principal
Asus Chromebook C202SA-YS02 Bezel Replacement
Qué necesitas
  1. Asus Chromebook C202SA-YS02 Bezel Replacement, Bezel: paso 1, imagen 1 de 1
    • Using a flat blade, remove the two screw covers on the front of the bezel. They are attached by adhesive, so you may have to dig at it a little bit.
  2. Asus Chromebook C202SA-YS02 Bezel Replacement: paso 2, imagen 1 de 1
    • Unscrew and remove the two Phillips #1 4.5 mm screws that are now visible.
  3. Asus Chromebook C202SA-YS02 Bezel Replacement: paso 3, imagen 1 de 1
    • Using the plastic opening tool, carefully pry off the bezel. It will come off entirely, so be careful not to break it.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 689
