Saltar al contenido principal
Asus Chromebook C202 Wireless Card Replacement
Qué necesitas
  1. Asus Chromebook C202 Wireless Card Replacement, Back Panel: paso 1, imagen 1 de 3 Asus Chromebook C202 Wireless Card Replacement, Back Panel: paso 1, imagen 2 de 3 Asus Chromebook C202 Wireless Card Replacement, Back Panel: paso 1, imagen 3 de 3
    • Remove Phillips #1 screws from the bottom of the Chromebook using a Phillips #1 screwdriver.
    • Ten 8 mm screws
    • Two of the screws are hidden by rubber caps along the rubber rest of the device. Use tweezers to get them out.
  2. Asus Chromebook C202 Wireless Card Replacement: paso 2, imagen 1 de 1
    Herramienta utilizada en este paso:
    iFixit Opening Tool
    $1.99
    • Place the plastic opening tool into the edges between the front of the Chromebook and the back of it with the upper scoop of the opening tool facing upward.
    • Push down on the plastic opening tool to unhinge the top portion of the Chromebook from its lower portion. Opening the Chromebook all the way where the display touches the ground helps in opening up the top edge.
    • Use your hand to gently lift the top portion of the Chromebook from the bottom portion of it to avoid damaging the ribbon cables.
  3. Asus Chromebook C202 Wireless Card Replacement: paso 3, imagen 1 de 1
    • Gently disconnect the ribbon cable connecting the trackpad to the motherboard.
    • Gently disconnect the ribbon cable connecting the keyboard to the motherboard.
  4. Asus Chromebook C202 Wireless Card Replacement, Wireless Card: paso 4, imagen 1 de 1
    • Remove the black and white wires from the wireless card.
  5. Asus Chromebook C202 Wireless Card Replacement: paso 5, imagen 1 de 1
    • Unscrew the single 4 mm Phillips #1 screw pinning the wireless card in place.
  6. Asus Chromebook C202 Wireless Card Replacement: paso 6, imagen 1 de 1
    • Gently pull the wireless card away from the motherboard.
Conclusión
Equipo
USF Tampa, Team 3-1, Passmore Fall 2016 Miembro de USF Tampa, Team 3-1, Passmore Fall 2016
USFT-PASSMORE-F16S3G1
Miembros de 4
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 29
Todo El Tiempo: 1,875
